Reply 1180 of 1301, by keropi
- l33t++
zb10948 wrote on 2025-01-18, 19:08:ofc I did.
It's not a mapper issue either because Winamp also doesn't work, opening the device directly.
Both players (Winamp with internal plugin and Media Player through mapper) switch their respective system normally but no audio.
is this a fresh win95 installation or you upgraded from an existing one with some other soundcard prior installed?
it might also be the case that win95 need the previous version of the driver - I attach the generic v272 one , give it a go if this works better or not
I do not remember any win95 issues (but I guess most people just use 98SE nowadays) but I do remember issues when a previous soundcard driver was installed.
you will probably mess up win95 with adding/removing drivers so be prepared for this... :\
🎵 🎧 ⏳ ⚡ SoundVision PRO,MK1869 , PCMIDI MPU , OrpheusII , Megacard and 🎶GoldLib soundcard website
