First post, by kotel
- Oldbie
Recently I got an seagate ST2383N drive from scrap. After fixing it up I connected it to my SCSI controller and booted into xp.
The drive is detected as its codename (IMPRIMIS 94241-7). After I got to diskmgmt I found out the partition was "unknown" even tho it was FAT. Activated it using diskpart (all the options to modify in diskmgmt are greyed out, only remove partition is un-greyed). Then I tried assigning a new drive letter but that failed due to no volume selected. I have selected the right disk and partition, but no go.
Now since this HDD probably(?) came out of an IBM or compatible PC I suspect there's gonna be some stuff that's unarchived and I'd like to make it archived, but this darn issue can't let me.
Anybody here that could help me out?
"Sent on a mission, to protect the last treasures. Through struggle and strife we can see the light. Even if our mission is partially complete, Our efforts are not in vain.
Let that be our legacy."
-Stronghold 5-5
