Reply 55820 of 59086, by Kahenraz
I've been staring at it for a while and still can't figure out what it is. Maybe that's why do many people passed it up. What is it?
Reply 55821 of 59086, by PcBytes
smtkr wrote on 2025-01-23, 03:23:
PcBytes wrote on 2025-01-22, 10:21:
Guess I'm closer with each step I take to resto-upgrading my childhood PC 😁
Geforce 3 Ti200, 64MB tho. It's good as it is, given I hardly come across anything else than Geforce 2 and 4. The thing above it is a VGA-HDMI adapter so I can use it on my capture card.
Is that a Palit card? I vaguely remember someone making those purple PCBs, but I can't remember who it was.
Palit indeed. There's a somewhat "rare" sticker on the back that fully says "PALIT DAYTONA Original Board" right around where the VGA port is placed. I'd say it's kinda rare since most purple cards from them used to either have no "Original Board" label at all, or simply have Palit without the Daytona text.
Reply 55822 of 59086, by ChrisK
acl wrote on 2025-01-23, 00:12:
- Sealed P3 1000/100/Slot1 (i will not keep it sealed forever)
Just beware of the "Important Configuration Message".
Once it is unboxed you can't return it!
And according Murphy's law it WILL damage your important any other board and equippment and you WILL loose any warranty.
Unless...you buy one of those Intel boards.
Wait...you already have one of these!?
Wes1262 wrote on 2025-01-22, 08:21:
Found this in a random joblot on FB. Went unnoticed for months. I still haven't received it. I hope it works.
Yes please, tell us what this mysterious fan behind ESD foil belongs to.
Or no, better wait some more and let's have some more guessing here to make it a bit more entertaining.
Curious what ideas people come up with.
(Don't have any idea myself, honestly, other than it beeing some kind of graphics card.)
RetroPC: K6-III+/400ATZ @6x83@1.7V / CT-5SIM / 2x 64M SDR / 40G HDD / RIVA TNT / V2 SLI / CT4520
ModernPC: Phenom II 910e @ 3GHz / ALiveDual-eSATA2 / 4x 2GB DDR-II / 512G SSD / 750G HDD / RX470
Reply 55823 of 59086, by acl
ChrisK wrote on 2025-01-23, 08:01:
Once it is unboxed you can't return it! And according Murphy's law it WILL damage your important any other board and equippment […]
And the plagues of Egypt, rivers of blood, locust swarms and days of darkness.
Thank you for warning us Intel.
Reply 55824 of 59086, by PD2JK
As a 12 year old, I opened up a lot of old PC cases. One time, there was this thin/flat HP system. Inside was an i960 CPU. Never saw one, so learned about differences between CISC and RISC. At the time, for me the system was completely useless, so I scooped the processor out, and tossed the rest of it. Now, if I search for pictures it was probably an HP 700/RX X-Terminal / Netstation (?)
Years later, I took interest in i960 accelerated hardware. Already have a big ass SCSI RAID controller, but a NIC was missing. So:
The attachment DSC_3018.JPG is no longer available
has all kinds of stuff
Reply 55825 of 59086, by PcBytes
acl wrote on 2025-01-23, 08:15:
"RETURN THE CPU, OR SUFFER MY CURSE!"
Reply 55826 of 59086, by BitWrangler
PcBytes wrote on 2025-01-23, 12:42:
Yeah but soon after release you could disable the serial number that marked you and your kin unto the 7th generation... ... unless it went on an Intel board where they "forgot" to put that in the BIOS.
Reply 55827 of 59086, by ChrisK
Not exactly today but within the last couple of weeks:
The attachment P4i65G.jpg is no longer available
Sellers pic.
Came with a 3.4GHz Northwood and 2x 512MB DDR.
Not that I needed this but it was cheap and it's supporting even Willamettes which I've had no other board for.
And those two:
The attachment Kyro_PCI_1.jpg is no longer available
32MB was advertised as working, 64MB as not working.
At first they behaved odd...
The attachment Kyro_PCI_2.jpg is no longer available
The attachment Kyro_PCI_3.jpg is no longer available
...but after a good cleaning of the larger one (the smaller one was in perfect condition) and on another board they obviously both work just fine.
The attachment Kyro_PCI_4.jpg is no longer available
So everything good this time.
Now I'm thinking about changeing the Riva TNT against one of them in my K6-III+ system.
But not sure if that's a good idea.
Reply 55828 of 59086, by Wes1262
Kahenraz wrote on 2025-01-23, 07:14:
it's a
Spoiler
6800 ultra
Reply 55830 of 59086, by nfraser01
PD2JK wrote on 2025-01-23, 08:41:
Seen them on RAID cards, but never on a NIC... Nice
Reply 55831 of 59086, by nfraser01
Found hiding in a job lot of random stuff...
Reply 55832 of 59086, by Ozzuneoj
Wes1262 wrote on 2025-01-23, 14:51:
it's a
Spoiler
6800 ultra
Ah! I got it! I was going to say I haven't looked yet and then post that it was a 6800 Ultra, but when I hit quote it reveals your spoilers in text so... yeah. Definitely a 6800 Ultra.
Any idea if it's PCI-E or AGP? Can't quite make out whether it has an SLI connector or not.
Either way, nice find! 😁
Reply 55833 of 59086, by dionb
Got myself an interesting one:
The attachment mediagx.webp is no longer available
A Cyrix MediaGX board with Cx5530 chipset, but which one... it doesn't match with any of the ones on TheRetroWeb. And then there's this:
The attachment general_softwar.webp is no longer available
General Software Inc. Embedded BIOS 4.3 instead of the usual AMI/Award/Phoenix. Inside the BIOS setup, there's an 'About' tab that says this is an evaluation board, so possibly specific to General Software.
Unfortunately only a very limited number of EBIOS modules were compiled for the image on it, so only drives and ROM shadow config can be set, nothing about the integrated devices like SB16.
If I can ever find sources to build my own EBIOS I could have a lot of fun with this. But I haven't been able to so for. So...
After backing up the EEPROM, I flashed it with ECS P5GX-M BIOS, given that the boards appear functionally identical and yes, it works.
Audio is interesting, a very metallic-sounding FM synth, but pretty decent SB16 otherwise, with absolutely no software needed to work in DOS - just set resources in BIOS and point games to it. Haven't been able to test compatibility a lot yet, Civilization failed to produce any audio (old AdLib game, maybe the audio is only listening to 0x220 not 0x388...), Ascendancy failed to run due to failed memory check (60MB free was too much for it 😉 ) and OMF also failed to run without error message. Will try a bit more (including MIDI) tomorrow...
Reply 55834 of 59086, by bjwil1991
Bought this Bondwell B310 at a thrift store (needs a charger brick and it'll get inspected and repaired before fully testing it).
The attachment 20250123_141252.jpg is no longer available
The attachment 20250123_141255.jpg is no longer available
My ultimate goals are to give the display a major upgrade to an IPS, HDD replaced with flash storage, design or find a sound card that I can use for games and stuff, and above all, use it to write novels.
Reply 55835 of 59086, by JvV
Bought these items this week locally. Not for Evilbay prices but a nice price.
Roland LAPC-I + MCB-1 (Both boxed)
Roland RAP-10 + MCB-10 + 3 of the 5 install disks.
Reply 55836 of 59086, by zuldan
JvV wrote on 2025-01-24, 08:02:
Ultra lucky. Worth we’ll over $1000.
Reply 55837 of 59086, by dionb
Ah, I think I spotted those too - but too late of course. Good to see they went to a Vogon 😀
Reply 55838 of 59086, by Kahenraz
Danggg. Good score. Welcome to the Roland LAPC-I club!
Reply 55839 of 59086, by JvV
Kahenraz wrote on 2025-01-24, 09:06:
Thanks! Already had an Roland RAP-10 boxed in my collection. So real Roland lover here, also owner of an MT-32 REV0 and Roland MA-12C speakers.
