DOS games that require windows to play?
First post, by mothergoose729
Weird title I know. I have been messing around in 86box. On a Pentium computer with DOS 6.22 and windows 3.1 installed I ran into a few games that just refused to work. Mostly these are special edition titles of earlier DOS games.
  • Need for Speed SE (regular version works)
  • Star Wars Tie Fighter CD (floppies work)
  • System Shock Enhanced (regular version without high res modes work)
On my real DOS/Win9x machine I didn't remember running into any problems. So I tried setting up a P2 based machine around windows 95, dropping to DOS, and installing these games again and they worked just fine.
Which has me curious... what are these games that run in a pure DOS environment, but ONLY if certain windows components are also available? How does this work? Where do these games come from?
Is it possible to get them working in DOS 6.22 as well?
Reply 1 of 25, by feda
mothergoose729 wrote on 2025-01-27, 05:59:
There are no such games. A game running in pure DOS does not care whether or not you have a Windows installation.
More likely they just didn't like whatever hardware you were emulating in 86box.
Reply 2 of 25, by mothergoose729
feda wrote on 2025-01-27, 06:52:
If I swap the virtual hard drives between the two machines I get the same behavior. The Pentium won't boot NFSSE in dos 6.22 but it will on the wind0ws95 image and vice versa with the PII machine. The autoexec and config.sys files are identical. The only difference is one is FAT32 with windows 95 and the other is FAT 16 with DOS 6.22.
Reply 3 of 25, by Greywolf1
I’ve had games throw a hissy fit when emulators runs in windowed mode you sort of get the effect of a windowed games running in a windowed emulator.
Reply 4 of 25, by feda
I can tell you that NFSSE and Tie Fighter CD work perfectly fine in Dosbox. Windows is irrelevant.
Reply 5 of 25, by mothergoose729
feda wrote on 2025-01-27, 07:18:
Yeah it works in Dosbox. I'm not taking it for granted that Dosbox environment is identical to DOS 6.22.
I'm happy to be wrong, but I need a good reason to be wrong.
Reply 6 of 25, by ntalaec
There are DOS games like MDK or Ignition that have updates for 3D graphics cards (3DFX) which require Windows 95.
Also there are DOS games like Zoop that after copying the game files the installer runs Windows 3.1 to create the icons. According to the manual, the game requires Windows 3.1 to run (which it's not true).
The installer for Tyrian 2000 is Windows 95 only but the game is DOS only.
Reply 7 of 25, by Kalle
I have TIE Fighter CD and it runs fine in MS-DOS 6.22, both on my P133 and PIII 800. There must be another reason why it doesn't run in your case. Do you get any error message or simply a black screen when starting it?
Reply 8 of 25, by Gmlb256
Star Havoc is the only game that I know so far that sort of requires Windows 9x, the executable is a DOS application where LFN support is mandatory.
Reply 10 of 25, by thepirategamerboy12
Extreme Paintbrawl. The game is absolutely so bad it's good imo, the menus run in Windows but the game engine itself (Build) is DOS based.
Reply 11 of 25, by Joseph_Joestar
Didn't Bethesda's Redguard have a Windows installer, while the actual game ran in DOS?
It's been a long time since I played this, so I could be wrong.
My retro stuff
Reply 12 of 25, by eddman
Using 86box, I tested Need for Speed SE and Star Wars Tie Fighter CD on DOS 6.22. The former doesn't work with EMM386 but does work without it. The latter works with both.
ntalaec wrote on 2025-01-27, 08:29:
MDK and Ignition are hybrid DOS/Windows releases. They come with both executables on the CD.
Reply 13 of 25, by mothergoose729
eddman wrote on 2025-01-27, 13:20:
MDK and Ignition are hybrid DOS/Windows games. They come with both executables on the CD.
Interesting, maybe it has something to do with memory management.
Reply 14 of 25, by digger
Gmlb256 wrote on 2025-01-27, 12:27:
Interesting. I wonder if that game would work in pure DOS when DOSLFN is loaded.
I guess it depends on how the game's detection routine works. Does it just check if LFN is working simply by accessing a file by its long file name?
Reply 15 of 25, by dr_st
Joseph_Joestar wrote on 2025-01-27, 13:13:
Oh, I think quite a few games had that. It was common practice when it was assumed the average user had Windows, so there was an option to provide more "intuitive" installers, while taking advantage of Windows' ability to run DOS programs to avoid recompiling the entire game as a Win32 executable. Some example off the top of my head include Rayman Designer/Gold/Forever.
This may depend on the particular hardware (whether real or emulated) or on the EMM386 configuration. The DOS version of NFS:SE never had problems running with EMM386 (including EMS emulation) on my K6-2 machine.
Reply 16 of 25, by Gmlb256
digger wrote on 2025-01-27, 16:22:
It does work with DOSLFN (tested on MS-DOS 7.1), a DPMI server is also required as well.
Yes, the game does access the files by its long file name. Without LFN support, it will report errors with such files and the initialization would fail.
Reply 17 of 25, by eddman
I also tested System Shock Enhanced, with both the classic and enhanced exes, and it works fine with and without EMM386.
dr_st wrote on 2025-01-27, 16:33:
Yea, I tried again after a restart and it now works with EMM386. It is a very temperamental game, and with the windows exe too.
Reply 18 of 25, by Malik
If a game requires Windows, it will be mentioned on the box. A DOS game is what it is - a game that is played in DOS.
If the patch requires Windows, it will be mentioned in the readme file accompanying the patch.
An executable that requires Windows will display the message when running such executable in DOS - "This program requires Windows" or "This program cannot be run in DOS mode" and such.
If the DOS program doesn't run without error messages or hangs at the prompt after entering the executable, then it means there are other problems going on like memory problems - not enough conventional memory, existence or absence of expanded memory,etc., or sound driver problems, incorrect IRQ or address of the sound card, etc.
Reply 19 of 25, by chinny22
I'm only familiar with Need for Speed SE which installed ok on my Dos 6.22 / Win3x 486.
I can't remember if I had to manually run a different exe file. eg setup_d.exe, I know I had to do that for one of these cross over games that pure install.exe wasn't happy in dos.
