First post, by Anonymoose
Per the subject, I’m diagnosing some issues with said laptop that doesn’t seem to turn on. I received it without a hard drive and a replaced Dallas chip, so I assumed it had been worked on previously. The power brick seems to work, but the floppy drive doesnt spin up upon being turned on. I opened the internet power supply and nothing looked bad except this. Any thoughts? Anything else I should check? Thanks!
Reply 1 of 4, by pentiumspeed
One of the long tube of capacitor is bad. I had this happen long ago.
Cheers,
Great Northern aka Canada.
Reply 2 of 4, by Anonymoose
Welp, I’m back, this time with what I think could be the problem? I’ve replaced the five capacitors in the PSU, it still doesn’t work. I’ve noticed though that the previous owner replaced the Dallas chip with a modern equivalent and apparently scratched up the surrounding area. Could this be the issue?
Reply 3 of 4, by Paar
It definitely looks like bad desoldering job. Double check the continuity on the Dallas chip pins.
Does the PSU generate proper voltages?
Reply 4 of 4, by Anonymoose
The PSU generates proper voltages, and I don’t have the original Dallas RTC as it’s been replaced with a Necroware NW12887. I could still check that though.
