Help choosing right CPU throttler
Reply 20 of 21, by DustyShinigami
Dhigan wrote on 2025-01-31, 21:02:
As your are looking for lower speed, the cpu are quite easy to change with your config. Have you considered using a Pentium II 233 Klamath ?
See also Slot 1 cpu slowdown???
Once I get around to installing my new motherboard, that will give me much more customisable options via the BIOS. I was shown that I can configure the CPU speed, the FSB, and disable/enable the cache etc. With any luck, I probably won't need any utilities. 😀 Although some are convenient if I use a custom batch file to launch a game.
OS: Windows 98 SE
CPU: Slot 1 Pentium III Coppermine 933MHz (SL448)
RAM: Kingston 256MB 133MHz
GPU: Nvidia 16MB Riva TNT
Motherboard: ABit AB-BE6-II Intel 440BX
HDD: 30GB - IDE 3; 40GB - IDE 3; 80GB - IDE 4
Reply 21 of 21, by DustyShinigami
Does anyone have any recommendations for CPU throttlers under Windows? All the ones I've tried so far are for DOS, but I have a native Windows game that runs too fast that I'd like to slow down.
OS: Windows 98 SE
