The Ultimate 686 Benchmark Comparison
Reply 140 of 167, by Bullmecha
Do you have any benchmarks for dual Pentium pro CPU's ? Am running dual 200 at the moment and thinking of getting two Overdrives and was curious of the performance difference. Thanks
Just a guy with a bad tinkering habit.
i5 6600k Main Rig
too many to list old school rigs
Reply 141 of 167, by feipoa
I benchmarked a tonne of 3D games on my PPRO 233-512K build here: Graphics card for Pentium Pro build
If I'm not mistaken, this is the thread that I then replaced the PPRO cpu with a PIIOD and the performance gain was extremely disappointing. This is in stark contrast to when user luckybob ran PIIOD's on his board when providing data for 686 benchmark comparison. I haven't yet had time to determine why the gain was negligible during my tests, but as I now have a dual PIIOD setup with an Intel PR440FX, it is on my list to reinvestigate.
Reply 142 of 167, by luckybob
I think I mentioned it earlier. But the motherboard i was using had USWC enabled. ( by default, btw) it made a 50% performance difference in doom/quake.
Also, none of these benchmarks can even see the 2nd cpu. You'd have to be running some flavor of NT/2000/Linux AND a program that was multi threaded. When it comes to gaming on old systems, multi cpu is just for dick waving.
Also, there are major differences between chipsets and manufacturers. My ASUS P65UP5/8 motherboard FLYS with overdrive chips. But my Tyan boards are as buggy as a discount hooker.
Reply 143 of 167, by Bullmecha
Thanks for the info, I had skimmed through this post looking and read a bit on what you had posted.
Will explore options as I am still deciding what price I want to pay for the pair and I noticed someone else here had issues with the W6-Li board and the OD CPUs
i5 6600k Main Rig
Reply 144 of 167, by feipoa
luckybob wrote on 2021-11-29, 00:49:
You may have, but I don't recall specifically. That is an interesting observation. I thought USWC was an AGP feature? Were there some socket 8 boards which have this feature in the BIOS, or were you using a slot 1 AGP board with those downgrade adapters (slot1-to-socket8)?
Indeed, but perhaps the PR440FX board's BIOS has some fix of sorts that speeds things up with a PIIOD compared to the VS440FX board I used in the above noted thread.
I recall you had quite a bit of issues with those Tyans. Glad I switched gear and went with something else.
Reply 145 of 167, by luckybob
feipoa wrote on 2021-11-29, 01:18:
I'm not privy to the details of USWC, but I know the G250 Matrox loved it. And I used the P65UP5 for all of my original tests.
i recently got a 450GX board, overpaid quite a bit, but it had excellent memory throughput, but it has a crappy solder joint somewhere and doesn't post every time. I seriously have 100+ half-finished projects.
it's not the fault of Tyan. The boards were fine new (i presume). They just didn't age well.
Reply 146 of 167, by 385387386
I think AMD K7 (Athlon) is a 786 class CPU.
My first PC (1997)
IBM 6x86mx PR200
BIOSTAR M5ATA
16MB SDRAM
Now upgraded to Cyrix MII 291.5MHz (maybe PR400)
Reply 147 of 167, by Skorbin
I always thought that TYAN would be a good brand, but then I got hold of 3 used dual boards (one dual socket 370 and two dual socket 462)
Initially they worked good, but then they started to get flaky.
As I am not an electronics specialist, I gave it to one of our specialists in the DOSReloaded forum and he confirmed my suspicion: at least 2 of them used really cheap and bad caps.
After replacing them I got the Tiger 200T back and it is running stable as a rock. The two kings even compiled a current Gentoo linux in 3 days straight (ok, GUI/WM not yet installed).
So in principle they seem to be good boards, but not every component is up to their quality claims.
Reply 148 of 167, by Samir
Skorbin wrote on 2024-04-19, 12:59:
...at least 2 of them used really cheap and bad caps.
I don't think anyone that made these boards expected them to be still used today so while the components were top notch at the time, they were not made to last forever. This was par for the course back then (and still is to a certain extent). Luckily, today we do have access to long-life components, but in the era of planned obsolescence and 'price is the only metric', rarely are these type of components used unless it's a selling point.
Reply 149 of 167, by ruthan
Samir wrote on 2024-04-19, 18:00:
Well only, other option is emulation, or some FCPGA boards.. and as im looking at 86Box code commits (scope is huge and there is a lot of exception, special situation to handle) is this a long way to make emulation to be less buggy than original HW..
Im old goal oriented goatman, i care about facts and freedom, not about egos+prejudices. Hoarding=sickness. If you want respect, gain it by your behavior. I hate stupid SW limits, SW=virtual world, everything should be possible if you have enough raw HW.
Reply 150 of 167, by Samir
ruthan wrote on 2024-11-16, 20:40:
Yep, emulation has come a long way and there are some devices that can even run the code better than the original hardware. Still for me, there's something to actually touching and feeling the hardware of the era while using the software from that era.
Reply 151 of 167, by 385387386
Cyrix 6x86mx, M II are the last "true" x86 processor. Since Pentium, K6 are really RISC core inside.......
My first PC (1997)
IBM 6x86mx PR200
BIOSTAR M5ATA
16MB SDRAM
Reply 152 of 167, by gonzo
If somebody is interested in some benchmark results of an OC-ed Cyrix 6x86L-PR200+ at 210 MHz (it is a M1-CPU, not M II using MX), they can be found here:
Cyrix appreciation thread
I LOVE CPUs RUNNING IN [GonzoHz]
Reply 153 of 167, by mwdmeyer
gonzo wrote on 2025-02-01, 09:47:
I'm impressed you got it to 210MHz! Saying that, the 6x86L (non MX) is an awful CPU unless you are doing DOS or Windows Business Apps. It's FPU is like 2/3rds of a Pentium based on MHz. MX version seems to fix a few bugs too.
Reply 154 of 167, by gonzo
mwdmeyer wrote on 2025-02-05, 01:45:
Thanks!
The biggest advantage of the MX-version of the Cyrix-6x86 is the built-in recognition as a "pentium-class-CPU" for the most software - thit increases the useable software with it by far (compared to the 6x86L).
And, of course, the MMX-extention-set.
Reply 155 of 167, by Señor Ventura
Didn't see this thread...
IBM Aptiva 2144, chipset SIS 5511/12/13, integrated svga SIS 5598, with pentium 200, 256KB L2 cache, 64MB of RAM, S3 trio64+, Voodoo 1, Sound blaster AWE 64 gold.
Let's go, then:
-Bios shows the cpu as pentium 120mhz, some benchmarks thinks it's a pentium 120, but probable performs like a pentium 200, i don't know.
-CD drive is setted up as "compatibility mode" instead "high performace". It is 48X but reads at 8X.
-Benchmarks were done under windows 98, not DOS.
-Top Bench reach 280 (not in images).
-Benchs includes speed sys, and quake.
Images:
Reply 156 of 167, by gonzo
Señor Ventura wrote on 2025-12-10, 16:52:
IBM Aptiva 2144, chipset SIS 5511/12/13, integrated svga SIS 5598, with pentium 200...
I'm pretty sure, the installed P200 is clocked real at 120 MHz (maybe the mainboard isn't able to do more, or maybe the 120-MHz-CPU was just replaced by the P200 "as it is" and no jumper-adjustment was done to reach the higher frequency)
Reply 157 of 167, by Señor Ventura
gonzo wrote on 2025-12-10, 18:43:
I just was thinking about that... maybe i need to set some jumper.
I will try to change the cd drive to "high performance", actually i'm having 8x when the unit can reach until 48x.
About the rest of the tests, Do it looks normal?.
Reply 158 of 167, by luckybob
i would fix the cpu running at 120mhz before I scrutinize any other test. The CD speed is actually a blessing. 8x drives run nice and quiet, having your disk spin up and down to 48x is annoying. I'd personally leave it be, unless you intend to dump 100 disks from cd to your hard drive.
Reply 159 of 167, by bertrammatrix
Didn't see this thread... […]
Let's go, then:
Images:
That Speedsys cpu score would be accurate even if the processor detection / frequency was not, hence I would trust it is running at 120mhz
No wonder you have low performance for a 200, if it's not a 200 😀 Should it be? Ie does it have a 200 CPU inserted?
