9800XT low score in 3DMark03 on WinXP with a 3700+
First post, by zuldan
Getting around 3000 (driver v3.8.421). I installed my 5950U (driver v45.23) on the same machine (MSI K8T Neo) and I’m getting over 6000. Reinstalled Windows XP, installed VIA chipset drivers (4in1435v.zip) but same issue. I then installed the 9800XT on another machine (ABIT KV8-MAX3) and still the same issue. Is there anything I can tweak?
The 9800XT is getting 201fps in Quake 3 (1024 / max settings). Haven’t tested any other games yet.
Reply 1 of 66, by Joseph_Joestar
zuldan wrote on 2025-02-02, 09:24:
Try using Catalyst 6.2. Unlike Nvidia, newer ATi drivers actually improve performance while not causing any new compatibility issues. There's no reason to use older drivers with ATi Radeon cards, unless you're running them on a really old CPU or something.
That driver version seems way too old for an Athlon64 motherboard. Use Hyperion Pro 5.09A instead.
My retro stuff
Reply 2 of 66, by zuldan
Joseph_Joestar wrote on 2025-02-02, 09:31:
Try using Catalyst 6.2. Unlike Nvidia, newer ATi drivers actually improve performance while not causing any new compatibility i […]
Thanks for the recommendations. I’m a ATI noob. I didn’t know newer drivers are better with ATI. Any reason why you didn’t recommend Omega drivers?
Reply 3 of 66, by Joseph_Joestar
zuldan wrote on 2025-02-02, 09:38:
I never felt the need to use them on my R300 and R400 cards. The latest official Catalyst 6.2 driver offers plenty of performance under Win9x.
BTW, if you're dual booting Win98 and WinXP, you want to use Catalyst 6.2 on the former and Catalyst 7.11 on the latter. That version introduces perfect table fog emulation under WinXP, while also being the last one that is compatible enough for some problematic OpenGL games from the early-mid 2000s, like Star Wars KOTOR and Neverwinter Nights. You may also need .NET Framework 2.0 for the Catalyst 7.11 Control Center to work properly.
To clarify, my previous statement that ATi's later drivers are better is true for Win9x. But for WinXP, there are some minor OpenGL compatibility concerns when going higher than Catalyst 7.11.
My retro stuff
Reply 4 of 66, by zuldan
Joseph_Joestar wrote on 2025-02-02, 09:59:
I never felt the need to use them on my R300 and R400 cards. The latest official Catalyst 6.2 driver offers plenty of performanc […]
I'm only intending running WinXP on this machine. I installed .NET 2.0 and the Catalyst 6.2 drivers just for fun (and made sure the old drivers were gone with Driver Cleaner Professional v1.5) and the performance dropped even further.
The attachment Score.JPG is no longer available
The attachment Info.JPG is no longer available
I uninstalled the 6.2 drivers, rebooted and tried to install Catalyst 7.11 drivers as you recommended but the installer refuses to work. I was able to manually install the drivers via Device Manager but performance was the same.
The attachment Error1.JPG is no longer available
The attachment Error2.JPG is no longer available
The attachment Error3.JPG is no longer available
I got a feeling the 9800XT is performing fine, it's just a quirk with 3dMark03. There must be some ATI tweak or 3dMark03 setting I'm not configuring. I looked up Quake 3 performance https://www.guru3d.com/review/ati-radeon-9800 … review/page-15/. Guru3D got 171 FPS @ 1024 and I'm getting 201 FPS @ 1024.
Any other ideas?
Reply 5 of 66, by Joseph_Joestar
zuldan wrote on 2025-02-03, 08:53:
I've seen that happen a few times, usually when a previous version of ATi drivers was installed. Driver cleaner utilities don't seem to help with that, for some reason. But installing .NET Framework 2.0 followed by Catalyst 7.11 on a clean WinXP installation has always worked for me.
Any other ideas?
Not many I'm afraid. Try a clean install of WinXP + SP3 followed by VIA Hyperion Pro 5.24A drivers (since you're running XP), .NET Framework 2.0 and Catalyst 7.11. If the card underperforms on a clean install like that, it's possible that 3DMark 03 has some issues with it. Have you tested the performance in other Direct3D applications? Period correct games for that would be Halo and X2: The Threat.
By the way, IGN has a review of the 9800 XT where they test it with 3DMark 03 and it seems to be working fine for them.
My retro stuff
Reply 6 of 66, by zuldan
Joseph_Joestar wrote on 2025-02-03, 09:01:
I've seen that happen a few times, usually when a previous version of ATi drivers was installed. Driver cleaner utilities don't […]
Any other ideas?
That said, IGN has a review of the 9800 XT where they test it with 3DMark 03 and it seems to be working fine for them.
I’ll do a reinstall and use the newer VIA Hyperion Pro 5.24A drivers (I forgot to mention I did use the 5.09 drivers in the previous test).
I’m wondering if it’s something silly like using a USB keyboard and mouse instead of PS/2. You would think by 2003 that wouldn’t be a problem.
Reply 7 of 66, by Joseph_Joestar
zuldan wrote on 2025-02-03, 09:46:
On the topic of silly issues, have you ensured that V-Sync is turned off in the ATi drivers prior to performing the tests?
I think 3DMark 03 can do that on its own, but manually setting V-Sync to "Always Off" should still be done for benchmarking, just in case.
My retro stuff
Reply 8 of 66, by Trashbytes
Just digging around on google .. many suggest that to get a proper score in 03 you need to set the slider to max performance.
Display Properties -> Settings -> Advanced -> 3D
Move that slider and see if it helps.
Also make sure AGP fastwrites are turned off in the BIOS . .they are know to cause issues with ATI cards.
You should be getting around 5900 - 6900 points, anything lower and something is not right since 03 is pretty much GPU based and CPU makes little to no difference.
AI is inevitable, there is nothing you can do to stop it, no Ironman snap to save you from the Basilisk.
Reply 9 of 66, by zuldan
Thanks to both of you for the advice.
I’ll turn off v-sync, move the slider to max and disable AGP Fast writes (it’s currently enabled) tomorrow. If that fails I’ll reinstall WinXP.
TrashBytes (in a PM) also mentioned trying it in a 939 board so that’s another option.
Reply 10 of 66, by zuldan
Ok here’s an update
1. Disabled AGP Fast Write in the BIOS
2. Reinstalled XP
3. Installed VIA Hyperion Pro 5.24A drivers
4. Installed .NET 2.0
5. Installed Catalyst 7.11 drivers
6. Made sure V-sync was turned off
7. Set Catalyst option to Performance
Got a 3DMark03 score of 3600. A nice little improvement but still massive performance issue.
BUT…
I think I found the problem. If you look at the specs on my card
The attachment 46CEEAA9-5971-4F75-B3ED-E5F9158FB6A2.jpeg is no longer available
The graphics clock should be 412Mhz and the memory clock should be 365Mhz https://www.gpuzoo.com/GPU-ATI/Radeon_9800_XT.html
Is it possible the previous owner flashed another BIOS? Or is it possible to set the graphics and memory clock speed in the BIOS?
I really hope the previous owner hasn’t down clocked the card to hide some issue. Arrrg!!
Reply 11 of 66, by nd22
I was trying to say the exact same thing: the clocks on your card are wrong! This is usually done in order to keep the card running OK if it is crashing at default clocks. Try MSI aferburner to set the correct clocks on your card by raising slowly - 10 MHz core and memory - and testing each time with 3dmark for artifacts. Watch the temps with GPU-Z older version.
Reply 12 of 66, by Joseph_Joestar
zuldan wrote on 2025-02-04, 11:03:
It's been ages since I bothered with that, but from what I recall, there were some BIOS editing tools for both Nvidia and ATi cards from that time.
Those tools would allow you to edit a BIOS rom file and set the core and memory speed to whatever you wanted. You could then flash the modified BIOS back onto the card, so that you wouldn't need to overclock it manually via RivaTuner and such. I don't remember the specifics since it was a long time ago, but maybe someone else has more info.
My retro stuff
Reply 13 of 66, by zuldan
Yep BIOS can be modified easily Re: Radeon 9800 XT Troubles - Need Advice
Looks like I’ve been scammed. As soon as I set the memory clock speed to anything over 200Mhz I get artifacts all over the screen. The memory must be screwed on this card.
Damnit! Feeling a bit bummed.
Reply 14 of 66, by Joseph_Joestar
zuldan wrote on 2025-02-04, 11:38:
Looking at your GPU-Z screenshot, in addition to the low clocks, it also seems like the memory bus on the card is 128-bit. On a Radeon 9800 XT, the memory bus width should be 256-bit.
It could be that GPU-Z is reading it wrong, so maybe double check with Everest Home Edition.
My retro stuff
Reply 15 of 66, by Trashbytes
Joseph_Joestar wrote on 2025-02-04, 11:48:
I think with just one odd thing that might be the case but we have several data points now and they all point to that poor card being touched in the no no spot.
Now it could be they threw a modded bios on it to get it stable with lower clocks but the memory bus thing ....I would be taking that cooler off and getting the number off the die and checking it.
My guess is its not a 9800XT die but possibly a modded 9600XT but that doesn't quite fit since it does have 8 pixel, 4 vertex and 8 ROP/TMUs which matches the R360 core, AFAIK there are no R360 cores with a 128bit memory bus so thats very odd on its own. 9800Xt GPU clock should be 412Mhz with 365 on the Vram, Now I really want to see what the number on the die is.
Reply 16 of 66, by zuldan
Yep it’s a 9800 Pro (maybe?) running a 9800 XT BIOS. That explains the 128bit.
The attachment 14A1F536-474F-42D9-870D-20608E37B955.jpeg is no longer available
Re: Bought these (retro) hardware today
Reply 17 of 66, by Trashbytes
zuldan wrote on 2025-02-04, 12:12:
https://img687.imageshack.us/img687/3513/dscf0032custom.jpg
9800 Pro also has a 256bit bus .. its using the same core as the 9800XT and has 380/340 clocks.
how game are you at removing coolers !
Reply 18 of 66, by zuldan
Here are pictures of the actual card
The attachment DB1E5733-B29C-4670-BF44-A0EF112097CF.jpeg is no longer available
The attachment BF1BE4D6-7595-4657-A512-D7088A30D62C.jpeg is no longer available
Reply 19 of 66, by Trashbytes
Thats not a 9800XT .. they didn't use that cooler on the XT cards, even the cap layout is different to the ATI reference models.
This is the reference ATI 9800XT card
The attachment 9800XT.jpg is no longer available
So that begs the question .. what did you get sold, and that sticker on the back .. its certainly a fake.
This is the 9800 Pro reference model for comparison
The attachment 9800 PRo.jpg is no longer available
