First post, by GunghoGeoduck
Hey guys, I was wondering if any of you have run into this or have any solutions...
I have a Super 7 rig with an ALI Aladdin V chipset which runs gorgeously with DOS-based operating systems (inc. W9X) but for some reason, NT5.x won't detect my optical drive.
It will boot from the CD and complete the text-based portion of the setup, and will even seem to access the disk in the "Please Wait" screen in the graphical portion too, but once the hardware detection phase completes, the next time it needs to install something, it tells me to insert the CD, but the only drives that are available are A and C. This happens on both 2K and XP. I have not tried earlier versions of NT.
I tried pre-installing 2K on another machine then moving the drive over to this PC which worked, but it still never detected an optical drive even after installing all the drivers I could think of from USB.
For troubleshooting, I switched off UDMA to my secondary IDE controller in my BIOS, changed ribbon cables to a 40-conductor one, and also swapped DVD drives. Nothing changed.
Any ideas would be appreciated.
Thanks!
