First post, by solipsist
Hi there ๐Ÿ˜€
First of all, thanks for all the effort put into dosbox, it's a really neat emulator if you ask me ๐Ÿ˜€
Now, i'm the lucky one who will have my own 100mbit server soon.
I'm now configuring my server in a virtualmachine wich i will hook up on the internet when i get the connection.
I want to have my own DosBOX IPX Tunneling server as well, so i can play oldschool games over the internet with my friends.
Basicly, i want to know if there's an option to start dosbox as system service. I've editted the autoexec.bat to automatically start the ipx tunneling server, now i only need to find a way to start it as a system service ๐Ÿ˜€ (and i want it to be silent as well)
Is this possible with dosbox?
Thank you.
Reply 1 of 5, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
I have made a java standalone tunneling server, it's on my homepage. Dunno if it's silent xD
1+1=10
Reply 2 of 5, by solipsist
Awesome, thanks ๐Ÿ˜€
Ill try it, and try to get it to work with SrvAny.exe
Ill post the outcome ๐Ÿ˜€
Reply 3 of 5, by solipsist
Thanks for the server, i've done the job, and it now runs fully silent as a systemservice.
If you like, i can make a guide how to do it step by step.
I have one question.
The executable seems to not have all classes within it or something
when i start it as service, it says it couldn't find the main class.
what i did is put all classes in the system32 dir, so it could find it because it's in the "path"
do you have a compiled executable wich doesn't need the classes? that way i can install it cleaner ๐Ÿ˜œ
Reply 4 of 5, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
Does it work, too?
Maybe there is a way to change the startup directory of the service?
Or instead of the executable you can try 'java -cp <path-to-the-class-files> Main'.
1+1=10
Reply 5 of 5, by solipsist
Yes, it works to ๐Ÿ˜€
I couldn't find a way to change the startup location.
Perhaps if i'd make a LNK file it woudl work
[edit]Argh, i just found out that if i log off, the server doesn't work no more, it is loaded, but it doesn't function
ill have to figure out wtf is going on[/edit]
[edit2]I've installed a program called Firedaemon, it solved all my probs ๐Ÿ˜‰)[/edit]
