First post, by Lostdotfish
Can anyone tell me if this module is compatible with the GUS Max 1.8 please?
https://www.alldatasheet.com/datasheet-pdf/pd … C16258HK50.html
No.
It's EDO, for GUS Max you need FPM.
In 2003, I voted in favour of joining the European Union. However, due to later developments - especially the restrictions on cash usage - I have withdrawn my support. DOWN WITH THE EU!
Grzyb wrote on 2025-02-08, 10:17:No.
How about this
UPD424260LE-80 NEC 40PIN SOJ PACKAGE 4 MEG 256X16
Lostdotfish wrote on 2025-02-08, 13:28:How about this
Yes, it's FPM, and confirmed to work - Gravis Ultrasound Max memory upgrade
Edit:
No, it's 80 ns, may be too slow.
According to the manual, 70 ns is necessary.
Grzyb wrote on 2025-02-08, 13:55:Yes, it's FPM, and confirmed to work - Gravis Ultrasound Max memory upgrade […]
Yes, it's FPM, and confirmed to work- Gravis Ultrasound Max memory upgradeEdit:
How about ....
MT4CI6257DJ-6 256K X 16 dram mt4cl6257 Micron smd soj 40 pin
Lostdotfish wrote on 2025-02-08, 14:18:MT4CI6257DJ-6 256K X 16 dram mt4cl6257 Micron smd soj 40 pin
FPM, 60 ns - should be OK.
