First post, by holoprox
- Newbie
The original BIOS stayed too long without window cover, the bios gone bad 🙁, if possible please upload a dump for ALL of our poor souls!
150+ retro computers on board!
80+ flightsticks!
80+ flightsticks!
AFAIK CGA cards do not have bios.
They do tend to have character (ep)rom .
Do not ask Why !
weedeewee wrote on 2025-02-08, 15:07:AFAIK CGA cards do not have bios.
Same shit, rom (циганин) of a kind
80+ flightsticks!
CGA cards don't have BIOS.
That ROM must be character generator, containing fonts for text mode.
If it's gone bad, the system should still boot normally, only without displaying anything in text mode - but if you blindly run some CGA graphics program, it should display correctly.
If you won't find the ROM for this particular card, try with the original CGA ROM - should be easy to find, and may be the same.
Nie rzucim ziemi, skąd nasz root!
No, wait a minute... that ROM is 2732, right?
The original IBM MDA/CGA ROM is 8 KB - won't fit.
You can find some 4 KB CGA ROM here - https://minuszerodegrees.net/rom/rom.htm - "CGA card for PC-2".
video worked without the rom, my friend did not hook it to the proper monitor the first time, sorry for bothering
80+ flightsticks!
I guess the primary character generator ROM is already integrated in the main chip.
The socket must be for optional secondary CG ROM, for those who need something other than the default CP437 character set.
I think the same. The ROM socket is likely meant for an EPROM holding a localized font.
I've seen quite some HGC/CGA combo cards with an empty socket.
