First post, by stealthjoe
I got a P3 s370 (667 Mhz) from online and noticed that it arrived with one pin broken. I checked the datasheet for P3 and noted that it is D33 (C1 location). It refers to AGTL + I/O. In addition, many of the pins were already slightly bent and wouldn't fall into the socket without any pressure. I didn't use even the slightest pressure for fear of damaging the socket.
Given below is the image of the broken pin (bottom right). My question is would the processor be usable without the D33 pin in case I manage to straighten the pins? Also for straightening I tried using a blade but it seems to be inefficient. Any thoughts?
The attachment IMG_20250208_155322.jpg is no longer available
Intel 845GEBV2, Pentium 4 2.4 Ghz, Geforce FX5600 256MB, 512MB RAM, 160GB HDD, Sound Blaster Live! SB0100 - Win 98.
