Reply 460 of 561, by Sneakernets
Another weird thing about this machine: the clock drifts like crazy. I'm currently using the latest version of PC/GEOS on mine, with the clock set correctly at 12:00 am on the dot this morning. It's 3:40pm as I'm typing this and the clock is already off by a full 10 minutes. So the idea of using this as a fun little clock is out of the window. There has to be a solution to this.
Edit: somehow between then and now the clock "corrected" itself. This is the wobbliest clock I've ever witnessed on a machine.
