Reply 360 of 446, by ]--Freeman--[
Yes! With read-only set, the values stay saved. But there is not sound in dos yet.
I've set the pci where audigy is plugged with IRQ 10 on the bios. I've reserved in bios IRQs 5,7,9 so any pci device choose this IRQs.
Apparently all is loaded without errors in dos mode. If I run sbecfg, I have all the parameters ok, but when I run "sbego", it hangs the program and sounds a pc speaker tone freezing the system.
In windows it's all ok and sounds without problem.
I don't know where is the problem....
