Reply 40 of 51, by Guld
myne wrote on 2025-02-12, 03:26:Completely different generation and symptoms, but an athlon I had, had bad caps. The only symptom I noticed was that the mosfet […]
Completely different generation and symptoms, but an athlon I had, had bad caps. The only symptom I noticed was that the mosfet area got super hot.
Once changed, they were quite cool.
I believe they were leaking too much.
Are any caps noticeably lower in resistance or hotter than the others?I realise mine were electrolytic, and yours are tantrums, but caps do tend to fail short. I don't know the speed of this process, but it's possible it could be slow.
Not that I've found yet, I replaced all of the tantalums on the 5V today and checked the old ones once out and got:
9.15 - 11.47 uF (should be 10uF, so, nothing odd there)
1.2-1.6 ohm ...with one of them at 2.2 ohm. maybe a little high, but honestly I didn't think it was that bad, just higher than the others.
loss at 0.4-0.6%
the one with slightly higher resistance was the one that appears to be for the CMOS volage? Replaced it, no real change though.
Starting to wonder if the system is really having issues with memory beyond the 3712kB config that seems to work so well. Seems to be unstable to varying degrees with any of my configs above that (with cache enabled, without they all work).
Another odd thing I happened to notice today is that when it's running normally, it's pulling 2.6-2.7 amps on the 5V line, but immediately drops to 2.1 amps when it freezes. Could just be that several chips are disabled, etc. and might just be a result of the freeze, but found it at least noteworth. It was measured with my ATX2AT that I'm using which tells me the current pull while it's running.
Is there any reason the tantalums on the -5, -12, or +12 could cause an issue? I didn't think so and I don't have any cards in that are using those so I haven't touched them.
