Rendition Verite Thread
Reply 761 of 823, by Canadair
Can You please report latest version of Rready? 3/Feb/25?
Reply 762 of 823, by sharangad
Canadair wrote on 2025-02-21, 20:17:
5th February 2025 (RLauncher should report 3rd Feb 2025). I did update the store page today. There was a reference to an HD400 being the minimum GPU for RRedline apps, I changed it to HD4000.
https://www.youtube.com/@sharangadayananda\
https://patreon.com/Rready
Reply 763 of 823, by Canadair
sharangad wrote on 2025-02-21, 20:24:
thank you
do we have a list of the add-on track which are working as of today
I tried some, but is really hit and miss
Reply 764 of 823, by sharangad
Canadair wrote on 2025-02-21, 23:20:
thank you do we have a list of the add-on track which are working as of today I tried some, but is really hit and miss […]
thank you
If you use a stock carset, more tracks will work. I'll post an update on the RReady thread.
I've managed to patch icr2 to do these things:
1) Allocate a full block of RAM, as much as himem reports (register edx) .
2) Register more than 65536 of RAM per memory block.
3) there's an int 31 call which does something strange and I have no idea what it's supposed to do. Need to find some documentation on dos/4gw. I have some info, but the specific call is missing. This call might be allocating selectors for memory blocks, but I don't know., if it is it needs to be changed to use a universal selector.
Reply 765 of 823, by Postman5
I have a Rendition Verite V2200 4MB AGP and I really like how it runs Resident Evil.
The card has 4 IS of 1MB... Is it worth replacing them with 4x2MB?
Reply 766 of 823, by Nemo1985
I remember I did the test between a 4mb and a 8mb with 3dmark the difference was noticeable.
Reply 767 of 823, by eol
Good day to all! I ask Tiido and those who can help me understand how to turn a 4 MB card into an 8/16 MB card to respond? Physically, such a card exists. But even with drivers for the 8 MB version, the system only sees 4 MB. We are talking about Diamond with a v2100 chip. Perhaps the problem is in the chip? Or is it possible to replace/add resistors or something else? Thanks in advance for any help
Reply 768 of 823, by sharangad
eol wrote on 2025-03-06, 11:43:
You need to mod the BIOS. *This is risk*. RReady, the rendition wrapper mods the V1000 BIOS it uses at runtime to support 16 MB. But I haven't successully modded a V2000 BIOS to work with it.
[EDIT] It's entirely possible V1000 boards don't have the necessary hardware to support more than 4 MB. Just because it works for the wrapper doesn't mean it'll work for physical hardware.
Reply 769 of 823, by Nemo1985
If you mean the v1x00 I don't know, if you mean the v2xx version you don't need a modified bios.
Increase the memory amount requires to swap the chips and add some cables, Tiido did it some years ago.
Reply 770 of 823, by eol
Nemo1985 wrote on 2025-03-06, 11:55:
Thank you! The memory chips have already been replaced. The card works, but, as I said above, it still sees the same 4 mb. I have no idea what to do next
Reply 771 of 823, by eol
sharangad wrote on 2025-03-06, 11:48:
Thank you!
Reply 772 of 823, by Nemo1985
eol wrote on 2025-03-06, 12:04:
The card that has been upgraded already had 8mb. What card do you have?
That is my model (actually I think it's a cheap no name model):
https://www.512bit.net/rendition/rendition_verite_v2200.html
If it still detects only 4mb I think the problem could be the missing address lines.
Reply 773 of 823, by eol
Diamond Stealth s220. New memory - 4 blocks m32l1632512a (EliteMT)
Reply 774 of 823, by Nemo1985
eol wrote on 2025-03-06, 12:16:
Different layout then. Have you verified the pinout of the old memory chips and the new ones?
Reply 775 of 823, by eol
No, I don't think so. I didn't do the transplant, and the master hardly took this into account
p.s. as far as I remember, I checked it in Quake (triple buff on) - with 4 mb this causes known problems
Reply 776 of 823, by Nemo1985
eol wrote on 2025-03-06, 12:29:
So you are saying that who swapped the memory chips didn't take care of the new address lines with bodge wires? Well you have the answer where the problem is.
Reply 777 of 823, by eol
Thank you very much! I myself am not very good at such things. I hope the master will easily fix the problem)
Reply 778 of 823, by Nemo1985
eol wrote on 2025-03-06, 14:41:
Well the so called "master" should have been aware of this issue if he is knowledgeable.
That's how the card Tiido modified:
The attachment IMG_20250306_154719_cr.jpg is no longer available
Good luck
Reply 779 of 823, by eol
Nemo1985 wrote on 2025-03-06, 14:50:
Well the so called "master" should have been aware of this issue if he is knowledgeable. That's how the card Tiido modified: […]
Good luck
Thank you! : )
