RubDub2k wrote on 2025-02-23, 00:16:And I tried looking into putting in another small fan in there, but unless I tap into the other fan header on the motherboard (there's only one header of course, thanks Dell), I wouldn't have any way to power it (easily).
No spare molex connector for an HDD?
If there is one, you could easily use that with an adapter (or do it the oldschool ghetto style and just shove the fan wires in the connector. 🤣 )
I'm not 100% sure about the Optiplex GX280, but the GX270 and older era ones don't have fan control on the motherboard's fan header. So if it's the same for the GX280 (I think it is, but I don't remember anymore), then there would be no point to try to power any fan from the motherboard's header.
Also, you can add fans, but the question is if they really will solve the imbalance issue between intake and exhaust airflow.
RubDub2k wrote on 2025-02-23, 00:16:I spent a ton of time confirming the graphics were working properly and not the issue (I lowered and raised the resolution and cut down and maximized the settings, and saw essentially no performance improvement at all and essentially identical frame dips at all those different settings in the same situations/game locations), and given the house-fan/open case test I did on the cpu, thermal throttling is the only thing that seems to make sense as to why I am experiencing such significant frame dips (consistent 70-300 suddenly down to 30-40 in some cases).
Hmmm... that's an interesting bit of info there.
When you say the game starts to frame-dip, does that last for just a few seconds and triggered only by certain events on the map, or does it start to happen only after 10-20 minutes of gaming, when the CPU has had time to heat up?
Reason I ask is because I recall experiencing the former on a much more powerful system once or twice. I can't remember if it was on a high-end C2D (3 GHz) or newer C2Q (Q8300)... but it was very strange, because I remember it was a rather powerful system for HL2 game engine. Yet, every once in a while, I'd get these frame dips, sometimes even way below 20 and into the teens, triggered by something on the map (I can't remember if it was the gibs of some object or what.) But again, it was very strange behavior and only happened on that system. If that's what's happening to your game, then the Cedar Mill CPU won't solve this (but hey, at least you will still have a cooler PC? 😀 )
On the other hand, if your frame dips only happen after the CPU has had time to warm up, then that's more likely to be CPU throttling, especially if the framerate continues to stay low all the time afterwards, at least until you open the PC case.
Lastly, I don't remember how well the P4 architecture ran HL2... but to be honest, frame dips down to 30-40 FPS doesn't sound too abnormal for running the game on a CPU from that era. That said, rather than dealing with constant FPS changes and possible rubber-banding, perhaps consider limiting the framerate of the game either with something like RTSS (comes with MSI Afterburner), or just by using the command "fps_max xx" where xx is the framerate you want to limit too. I usually do 60 FPS if I'm running on an LCD monitor and 85 FPS if I'm gaming on a CRT. This will also off-load your GPU's power consumption a little, which in turn could also off-load the CPU a little as well.
RubDub2k wrote on 2025-02-23, 00:16:Perhaps when I swap in that P4 651 I'll check the cap dates like you suggested.
Just check if they are Nichicon HM or HN series... and if they are, only then bother to check the date codes. If you have Rubycon MCZ or Panasonic FL, you probably won't have any issues (at least for now and the next however many years / a decade these caps are still good for.)
RubDub2k wrote on 2025-02-23, 00:16:I'll update this thread once I install that P4 651 Cedar Mill so that anyone else running into this oddly exact or similarly related issue can reference it.
Awesome, thank you! 😀
RubDub2k wrote on 2025-02-23, 00:16:the 651 is coming from China, so I got a few weeks to wait 🙁
You know, sometimes I really admire the thoughtfulness of the Chinese recyclers - instead of scrapping everything now as it comes, they seem to have saved / "put aside" some of the old computer parts somewhere, waiting for them to get old and more valuable again... which they have, somewhat ($10-15 is a lot better from a P4 CPU than $0.50-$1 it would produce in scrap precious metals.) Too bad they didn't think to do that with the older PCs from the 90's, particularly the 286, 386, and 486's. Then again, those contained a lot more gold and became worthless/obsolete too quick for anyone to anticipate one day these could be valuable. So it's a bit of a shame in that regard.
Wow, thanks momaka! I know I picked a pretty a pretty difficult project to tackle here with these 2001-2004 optiplex's, but I just find the look of them so goofy (in a good way). No longer are these computers the beige boxes of the 90s, but nor are they quite the "sleek black-and-silver" metal look of the late 2000s... just dark grey plastic in two tones, with a bit of the metal frame showing on occasion. That, and they are soft and rounded, which really make them stand out to me.
Hehe, yeah goofy is probably quite the right word to use, indeed.
I suppose I never paid that much attention to their looks... or alternatively said, they never stood out as anything special to me. Buy maybe that's their charm? 😀
Or maybe it's also because of the fact that I have two Optiplex (170L) and one Dimension (3000) machines from the same era, and I still use the two Optiplexes for basic web stuff sometimes, like posting on forums, email, and similar. One also has my entire MP3 collection and image/photo gallery, so it actually still sees quite frequent use. More importantly, that machine has been unstoppable ever since I got it. It served as a kiosk / desk PC in a local Park Police office from 2005-2011 or 2012. In late 2012, I got it and have been using it pretty much solely as my main PC from early 2013 until late 2023. It's been rock-solid in all of those years.
Now perhaps worth noting is that all of these are the regular "minitower" versions, so they do have more space inside and better cooling overall... but still far from great or even good. In particular, I have no problems with these machines in the winter, when the house temperatures are colder. In the summer, though, the fans will get annoyingly loud. Most of that is because there simply aren't enough air intake vents. Both the Optiplex 170L and Dimension 3000 have a 92mm exhaust fan + an 80 mm fan in the (ATX) PSU. Meanwhile, the intake is only comprised of two small vents on the front: one above the USB ports "nuk" and one under the front bezel. There's also a small vent on the back, next to the slot covers for the PCI cards... but really that's it. All three of these combined are not really enough for when the fans ramp up their speed in the summer. So what happens is the CPU fan starts to fight for air with the PSU fan, and they keep turning up and up to compete with each other. However, if I ever so slightly crack the side panel open on the bottom, the fans go back to normal low speed again.
Thus, even the larger Dell cases from that era are not great for cooling.
