Reply 20 of 34, by Commander_keen
- Newbie
I understood that after I was told that the resolution in the dosbox.conf ist just a fake and stretching a.s.o.
But as you said if I tell the game to run at 800*600 it will run at 800*600, no matter which size I set dosbox to use as output size.
So I did that, I set it to 800*600 in settlers II options. And all dosbox-settings concerning graphics back to the default ones. So I'm running this game at 800*600 now, don't I? If I still don't get the point, thanks for your patience.
If I do I can only repeat myself by saying: it runs fine (except some crashes where dosbox is closed completely). It only stutters if the auto-lock feature is disabled and it runs better if I put it to fullscreen (I guess because the priority is higher then as there are several other aplications running)
