Took me long enough but I've found a WinBook XP! Better, unlike my XP5, this one actually starts up every time! […]
The attachment wbxp.jpg is no longer available
Specs:
- Desktop Socket 3 Intel i486DX4 @75MHz (overclocked to 100MHz 😁)
- 32MB of RAM!!!! Fully maxed out.
- 1.3GB Hitachi HDD
- Windows 95
- 9.5" Active Matrix LCD @640x480
- WD90C24 Video
- ESS AudioDrive 1688
- Lexmark keyboard (same switches as a ThinkPad 755C!)
It really is an excellent DOS gaming system - this one even lets you pick between 640x400 and 640x480 scaling via a keyboard shortcut, unlike my XP5. It has a decent on-board speaker and sound playback works great. The keyboard and input device options (you could get these with a trackpoint, trackball, or even a trackpad) makes them super configurable systems.
Problem of course is that they're unreliable, largely due to the soldered varta battery that I've mentioned before in this thread. This XP had nearly no leakage and no actual damage - I replaced the battery with a new one.
These will also completely fall apart around the hinges unless heavily reinforced with JB Weld. I've done that to this unit and hinges are now a-ok. The downside is that you do have to loosen the nuts on the hinges to make them very loose or the plastic will still break, even with reinforcement. This is fine if you're using it at a desk (they're still tight enough to hold the screen up), but if you're using it on your lap then they will fall backwards very easily.
This laptop has one functionality issue - the LCD panel is suffering from what I call "subpixel disease" where subpixels around the corners and edges of the screen malfunction. It's the same issue that affects mid-late 90s IBM displays, although this laptop uses an uncommon Hitachi panel.
I have noted that the CPU cooling design in this laptop is extremely flawed. The CPU is located under a removable cover on the bottom of the laptop. The cover is made of metal, but it doesn't actually contact the CPU at all. When I applied paste to the CPU, it wasn't spread whatsoever when I reinstalled and then uninstalled this cover. I was going to leave it be, after all, the engineers deemed it ok, but then I checked to see if it would overclock to 100MHz.... and it did, and was rock solid stable. So I had to get rid of this bluetooth heatsink.
The attachment heatsink mod.jpg is no longer available
I ripped a copper contact plate off of a spare laptop heatsink I had lying around (it was from a Dell Latitude E6420). I then sanded off the thermal glue that was used to adhere it to the heatpipes, and then once it was flat, I sandwiched it between the CPU and that metal cover with thermal paste on both sides. This seems to have done the trick perfectly, as the paste spread and the metal cover now gets quite warm when the system is running. Overclock is still stable and it hasn't crashed a single time - nice! Saved myself having to pay out for a legit DX4-100 chip.
Eventually I will rebuild the battery to get this laptop portable again, and hopefully source a replacement LCD panel. It's definitely a great option!
Finally, a photo of my XP and XP5 together. I think I've changed my mind on which is the "ultimate" option for me - the 486 is still cooler in my opinion, but the extra Pentium performance of the XP5 is a big plus, and the screen is larger (and higher quality), and it has stereo speakers.... If only mine didn't have serious power issues that make it completely impractical to actually use.
The attachment winbooks together.jpg is no longer available
