First post, by spacesaver
I some how managed to melt 2 pins in a PCI slot, simply by plugging in an Audigy 2 card. The board was still working at this point, even the PCI slot that had a melt down.
Then, I removed the slot by cutting it into sections with a Dremel and using a heat gun on the back to pull it out, section by section. Then, I used an air compressor to blow out the solder in the holes.
This spewed solder every where, but you can still rub it off. Excuse me for this sloppiness, but I couldn't insert the new slot by pressing on it, while blowing hot air on the back. Finally, I could insert the new slot and use a soldering iron. Then, I cleaned the board with a toothbrush and isopropanol, trying to make sure there's no bridges caused by all the molten solder that was blown around.
The motherboard is https://theretroweb.com/motherboards/s/msi-ms-6156-bx7 (version 1.1), and the replaced slot is PCI2.
Here's a video of the power on with a POST card. The 4 voltages are fine, but none of the other 3 lights (CLK, RDY, FRAME, exclude RST) are on. There's no POST codes and the keyboard lights also blink sometimes.
https://www.dropbox.com/scl/fi/r9zlynj0bs7kc8 … t=jbvvh4b6&dl=0
So, I think that means the CPU is not even starting. What else does that mean and what could I do? Yes, you can tell me what dumb mistakes I made.
