KLund1 wrote on 2025-03-02, 08:04:WOW Thanks everyone!!
I get the PR now. Thanks
I have the manual. on page 17 & 18, it talks about jumper settings for CPU. I do […]
I have the manual. on page 17 & 18, it talks about jumper settings for CPU. I do not understand all that info and abbreviations fully. (probably just enough to burn up the board or cpu with a misplaced jumper)
The top part dose not have a K6-300 setting but the second section does.
So what would to proper jumper settings be for a K6 300?
I will flash the board to the latest BIOS, which can handle K6 300. But will it handle a K6-2 300 or K6-3 300? If so, would the jumper settings still be the same?
The board may be able to run a K2 or K3, but will the BIOS see it as that and be able to run it properly?
Again thanks for any input.
Hi Klund1,
I will try to answer your many question. 😉
CPU Support
Official CPU support for the TX97-E has been extended up to the K6-2/400 and K6-III/400 CPUs. This was documented in the FAQ section on the German Asus Support website. An archived copy from September 2000 can be viewed here:
https://web.archive.org/web/20001207093900/ht … p5cpu_supp3.htm
The latest 0112e-1 BIOS version for the TX97-E fully supports these 400MHz CPUs.
Note that the K6-PR300 (or K6-300) was the fastest K6-1 model, so opting for a K6-2 or K6-III allows you to select a faster CPU for this board.
But unofficially, even faster K6 models are supported by the TX97-E. These are: K6-2/450, K6-2/500, K6-III/450, K6-2+/450, K6-2+/500, K6-III+/450, and K6-III+/500.
However you need the patched 0112e_J2 BIOS to get support for these faster models and speeds. You can download this patched BIOS from TRW, or from my “Unofficial K6-2+/K6-III+ webpage”. The link is in my signature below.
As an added bonus, the patched BIOS fixes the 32GB IDE HDD limit bug for full 128GiB IDE drive support.
CPU speed setting
The jumpers settings from the manual for the correct CPU speed can be confusing.
The attachment TX97-E CPU speed setting.png is no longer available
The Frequency Selection for the External CPU clock via the three FS jumpers is straightforward. This setting controls the clock frequency of the signal lines (the Bus) between the CPU, the chipset, and the memory modules. The CPU also uses this clock signal internally, and multiplies this by the Bus Frequency ratio selection to generate the internal clock speed.
The Bus Frequency ratio (or multiplier) setting via the three BF jumpers needs some explaining.
The BF jumpers do not control the multiplier directly, but just set a high or low signal on the associated BF pin of the CPU. It is then up to the CPU how to interpret this, so it is the CPU itself that selects the multiplier from the BF setting. This is not the same for every CPU model, hence the table with CPU A, B, etc. below the BF settings.
For all AMD K6 models, use CPU E.
Extra CPU to BUS Frequency Ratio settings for K6-PR266, K6-PR300, and K6-2(+)/III(+):
5.0x -> BF0: 1-2, BF1: 2-3, BF2: 2-3
5.5x -> BF0: 1-2, BF1: 1-2, BF2: 2-3
6.0x -> BF0: 2-3, BF1: 1-2, BF2: 1-2
Note that the 6.0x setting only works on the K6-2CXT, K6-III, K6-2+, and
K6-III+ CPU. Other CPUs will do 2.0x with this setting. All K6-2/400 and
faster K6 CPUs have the CXT core.
CPU Vcore Voltage
For all K6 models, the required Vcore voltage is printed on the CPU.
This are the additional Vcore settings of the TX97-E:
2.1V -> VID0: 1-2, VID1: open, VID2: open
2.2V -> VID0: open, VID1: 1-2, VID2: open
2.3V -> VID0: 1-2, VID1: 1-2, VID2: open
2.4V -> VID0: open, VID1: open, VID2: 1-2
For 2.0V K6+ CPUs, you can safely use the 2.1V setting.
For all K6-2 CPUs, use the 2.2V setting (except the 2.4V K6-2/450AHX).
CPU speeds above 400MHz
This board uses the i430TX chipset, which is rated for a maximum 66MHz clock. So the 75MHz and 83MHz settings are overclocking the chipset. But to reach 450MHz ( 6 x 75) or 500MHz (6 x 83) CPU speed, these higher Bus clocks are needed because x6.0 is the highest multiplier of the socket 7 platform. Luckily the i430TX is very tolerant for overclocking.
However, the PCI bus is connected to the chipset via a fixed 2/1 divider and normally runs at 33MHz. So with a Bus clock of 75 or 83 MHz, the PCI bus is also overclocked to 37.5 or 41.5 MHz. PCI cards take 37.5MHz usually well, but with 41.5 MHz you may run into stability problems with certain cards.
Hope this helps.
Cheers, Jan
