First post, by OVERK|LL
- Member
Been having some random instability issues with the PS/1. Pulled the ODP, cleaned the board and the socket with alcohol thoroughly, re-installed, maybe seems a bit better? However, then it couldn't read my C-Drive after a few boots, which I'm thinking means the drive, that I thought was dying, is indeed dying, giving me an opportunity to move to CF cards.
Anyway, that's not the reason for this post.
I went to install Ontrack on the 2GB CF card, which mostly went OK. When it went to reboot, it did the same thing it does when I try to reboot Windows: It acts like it's rebooting, but then I get like a weird ch-ch-ch-ch beeping sort of chattering coming from the speaker and it never actually completes the reboot, it's just sort of frozen having this stroke. Unfortunately, I don't recall when this actually started happening, whether it was before or after I added the ODP and the ODP is a real pain to remove, so I'd like to avoid doing that again if possible.
The caps all LOOK good, the PSU is of course original, but I do recall it rebooting just fine at one point, but I unfortunately can't recall when exactly that changed.
Disabling/enabling APM in the BIOS has no impact on this behaviour.
Thoughts?
DD: Mac Pro 5,1 - X5690, 64GB, RX 580 - OCLP w/Sequoia
Projects:
- Hewitt-Rand 8088 - 640KB, 20MB, Hercules mono
- IBM PS/1 2133 w/Thermalwrong solder mod - ODP 486DX4-100, 32MB
- PCPartner VIB806DS w/233MMX, 128MB, G450
- Jetway J-TX98B w/P75, 256MB
