First post, by noshutdown
most isa vga cards are 16bit, which are believed to be faster than the 8bit ones. however, some chips have only 8bit bus so they are faked 16bit cards and performance should be the same as their 8bit variants, and some have been proved by experiments.
here are some confirmed chips:
oak037, chips450/451, wd90c00/pvga1, cirrus51020, their databooks all mentioned only 8 bus data pins.
and some suspected chips without datasheet:
tseng et3000 and trident8800 are suspected due to their extremely slow performance, comparable or even slower than the cards above, however i can't convince them from circuitry. i have both 8bit and 16bit versions of et3000 though, and am going to test them soon.
realtek 31030 and 3105 are also highly suspected, simple because their 16bit isa bus higher data pins are often left unconnected. however 3102 and 3103 can not be convinced from circuitry.
