First post, by stealthjoe
I recently got a board with a via onboard sound (VT1612A). I am facing some issues setting up the FM to work with DOS games. While trying to load the VIAFMTSR in Autoexec.bat or manually running the VIAFMTSR at command prompt, the system locks up - meaning the command is not getting initialized. Once viafmtsr.com is run, I just get a blinking cursor post the command under command prompt or while trying to get into Windows 98, the system hangs at the 98 splash screen.
Could someone please help on how to get VIAFMTSR working properly ? Thanks.
Intel 845GEBV2, Pentium 4 2.4 Ghz, Geforce FX5600 256MB, 512MB RAM, 160GB HDD, Sound Blaster Live! SB0100 - Win 98.
Reply 1 of 8, by Tiido
I don't know what can help with your problem but this may also help : VIA_AC97.866: DOS VIA 686A/B AC'97 init/mixer tool + FM TSR replacement
It is a replacement to VIAFMTSR that a friend of mine is developing which uses modern accurate OPL3 emulation cores for authentic sound and perhaps it won't have the same issue as VIAFMTSR has, or at least can possibly help to tell what it may be.
EDIT: Seems he hasn't actually released it yet, but I can tell that it will be awesome 🤣
His init tool may still be helpful, it definitely improves upon anything else.
Reply 2 of 8, by stealthjoe
Tiido wrote on 2025-03-11, 00:23:
I don't know what can help with your problem but this may also help : VIA_AC97.866: DOS VIA 686A/B AC'97 init/mixer tool + FM TS […]
Hello. I looked through the post but it looks like it definitely needs VIAFMTSR to enable FM support and this is where the issue is happening. Using VIAFMTSR, many dos games fail to load including Doom 1/2, Jazz Jackrabbit, Prince of Persia 2, etc.
Reply 3 of 8, by Pino
What is your south bridge? are you sure it supports SB emulation?
VT1612A is your AC97 codec, it doesn't mean your south bridge supports it.
Reply 4 of 8, by stealthjoe
Pino wrote on 2025-03-11, 17:55:
My south bridge is 82C686B.
Reply 5 of 8, by Tiido
stealthjoe wrote on 2025-03-11, 16:36:
The modern init tool may help with the problem, as it possibly sets up the actual sound hardware in a more compatible way and perhaps VIAFMTSR will behave better as a result, it won't hurt to try.
Reply 6 of 8, by stealthjoe
I noticed some trace damage on the back side of the motherboard right behind the southbridge. I am thinking if the issues could be due to it.
The attachment IMG_20250312_093724.jpg is no longer available
Reply 7 of 8, by Tiido
Trace damage can cause all kinds of problems, so it is better to go over these and make repairs when needed. Few of those traces do look like they have been severed not just scratched.
Reply 8 of 8, by stealthjoe
The strange part is that the DOS games sounds and FM work fine under 98. Under pure DOS mode initializing VIAFMTSR crashes many games. I am yet to find a thread where using VIAFMTSR causes crashes. So it looks like mine is an isolated incident (damaged traces possibly). However on using only SBCFG tool, the sound blaster works fine for most games, but no FM (obviously).
