First post, by altarofmelektaus
Don't really know where else to put this, but I'm trying to get a Prescott P4 working on a Jetway PT800DBP, and nothing other than Northwood processors seem to work. The board claims to support 800MHz FSB and was marketed as Prescott-ready, so I assumed it was just an out-of-date BIOS... flashed it to the latest Aug 2004 BIOS yet still, no dice. Tested multiple CPUs including a Prescott Celeron D with 533MHz FSB, none of those worked, but an 800MHz FSB HT Northwood worked fine. FSB jumpers are set to auto, and I'm running the auxiliary power input as well.
I've heard something about motherboards with failing capacitors not wanting to run higher powered CPUs, and thinking maybe this has something to do with it? Caps don't look bloated, but they are definitely low quality. This whole board itself is fairly low quality, which is exactly what I'm looking for (don't ask.)
Reply 1 of 22, by majestyk
Did you connect both additional power connectors (4-pin and 6-pin)?
The attachment p4.JPG is no longer available
Reply 2 of 22, by altarofmelektaus
majestyk wrote on 2025-03-16, 14:32:
Yes, I specifically try to use contemporary power supplies for P4 systems. It's a Hi-Pro that has been recapped, and I know it gives solid power.
Reply 3 of 22, by PD2JK
Do you have a diagnostics card? If it says '-- --' it is bios/cpu/board related.
Or any beeps?
Do the Prescott based CPUs work in another board?
i386 16 ⇒ i486 DX4 100 ⇒ Pentium MMX 200 ⇒ Athlon Pluto 700 ⇒ AthlonXP 1700+ ⇒ Opteron 165 ⇒ Dual Opteron 856
Reply 4 of 22, by altarofmelektaus
PD2JK wrote on 2025-03-16, 15:54:
Or any beeps?
Yeah, CPUs work fine on other boards, and the diagnostics card I have just gives ----. Strange that it works with Northwoods though.
Reply 5 of 22, by Karbist
Turn it on without the cpu cooler and see if cpu gets warm.
Reply 6 of 22, by PD2JK
Could the pins have different designations, i.e. does a Prescott have slightly other pin functions, and if so, I'm thinking of a dirty or malfunctioning socket.
Reply 7 of 22, by altarofmelektaus
Karbist wrote on 2025-03-16, 16:30:
It's not getting warm. The PC shuts off after holding down power button for 5 seconds instead of instantly shutting off too, if that helps.
Reply 8 of 22, by altarofmelektaus
PD2JK wrote on 2025-03-16, 16:47:
That's what I'm thinking, that or the Prescott ready labeling was just a lie!
Reply 9 of 22, by ElectroSoldier
I seem to remember having that board at some point in the past. I have the drivers for it (as on retroweb)
It doesnt support Prescott core processors. I had a 3.06HT 533 CPU in it.
Reply 10 of 22, by Sphere478
prescott needs bios microcode support and vrm support. your vrm might not be able to handle the voltage requested or the board may need a bios update.
Sphere's PCB projects.
Reply 12 of 22, by zyga64
It looks like there is mATX version of this board: PT8MS
And in web archive there is A04 (even A05 from 02/01/2005) BIOS for it, which is described as "Update CPU micro code for CELERON D E-Stepping." (Celeron D is Prescott)
https://web.archive.org/web/20130518232708/ht … dex-1.htm#PT800
The question is, are you brave enough to try it? 😀
Or maybe the latest official bios can be modified - based on the fixes from the PT8MS version ?
IMHO: It isn't worth the effort. Prescott is only sometimes faster than Notrhwood when compared clock-to-clock and more power hungry and hotter...
For science maybe 😀
Scamp: 286@20 /4M /CL-GD5422 /CMI8330
Aries: 486DX33 /16M /TGUI9440 /GUS+ALS100+MT32PI
Triton: K6-2@400 /64M /MGA-2064W+3dfx /YMF718
Seattle: P!!!750 /256M /MX440 /Vibra16s+SBLive!
Panther Point: 3470s /8G /GTX750Ti /HDA
Reply 13 of 22, by momaka
altarofmelektaus wrote on 2025-03-17, 02:19:
According to CPU-Upgrade, Prescotts are a NO-GO on this board.
https://www.cpu-upgrade.com/mb-Jetway/PT800DBP.html
FWIW, their info on CPU support (both official and unofficial) is relatively accurate.
The fact that so many Prescott CPUs have a big red mark next to them (unsupported) suggests this motherboard indeed probably never supported Prescott CPUs.
Perhaps Jetway intended to release support for Prescott CPUs later on (if, say, the board was released before they were available), but probably just didn't.
Wow, that's such a strange design!
I wonder why... or rather, what Jetway engineers were smoking at the time... for both a 6-pin Aux. power connector and a 4-pin 12V CPU power connector to co-exist on the same board.
FWIW, if there is a 4-pin 12V CPU connector, then the CPU VRM will almost certainly be using that.
I can only understand the 6-pin Aux. connector to be there IF there is something on the board that heavily uses either the 3.3V or 5V rails, like for example, an AGP Pro slot (where there are additional power pins.) Aside from that, it's probably one of the most useless connectors to have on a board. Looking at the Northbridge chipset heatsink on this board, it appears capable of handling no more than 10-15 Watts max of TDP... so not like there would be a need for an extra power for that.
altarofmelektaus wrote on 2025-03-16, 14:03:
Probably not a caps issue in this specific case... but you still might want to recap the motherboard if you intend to keep it / use it over time.
Jetway really like to use GSC / Evercon / Sacon capacitors A LOT, which are utter garbage. It's the same company that makes these, and the reason for the different names were because the company kept changing names to try to hide from the fact that they produced such garbage caps.
zyga64 wrote on 2025-03-17, 12:19:
For science maybe 😀
For gaming... yeah, probably not worth it indeed.
For non-gaming use and specifically for multimedia (video encoding / decoding), the extra L2 cache and SSE3 instructions do make it noticeably faster. The SSE3 helps even more for online use... just saying (as if anyone would still care to use a P4 in 2025 for browsing online... myself EXcluded 🤣 ).
altarofmelektaus wrote on 2025-03-16, 15:46:
Nice! 1-up 👍 for Hi-Pro from me too. They are well-designed and solid PSUs all around, often with very low noise & ripple on the output.
Reply 14 of 22, by H3nrik V!
Isn't the 6-pin just intended for PSUs that don't have the 4-pin Pentium 4 power connector, like a compatibility thing? Or does it explicitly say in the manual that both need to be connected?
Reply 15 of 22, by momaka
H3nrik V! wrote on 2025-03-21, 06:24:
Not really, because motherboards that don't have a 4-pin 12V connector will then use 5V to power the CPU. The 6-pin connector provides two extra 3.3V lines and only one extra 5V line - hardly making a difference for motherboards that tax the 5V-heavy for power-hungry CPUs (e.g. "high-end" P4 Willamate & Prescott, also late Athlon XP T-bred and Barton cores.) I suppose one extra 5V wire is still better than none... but considering those 6-pin connectors are the same style as the AT connector, I don't think they are rated for currents as high as the style that's used on the ATX connector. So in reality, that extra 5V line might not be helping as much as one would anticipate.
Reply 16 of 22, by H3nrik V!
momaka wrote on 2025-03-25, 17:01:
That sounds reasonable, I just wasn't aware of which half of the AT power connector, that was used in the auxiliary plug.
Reply 17 of 22, by PcBytes
I've seen that same connector show up on some Pentium 3 mainboards as well. Namely OR840 and XG-DLS.
Reply 18 of 22, by shamino
I've seen those 6-pin connectors on some higher quality Slot-1 boards (Intel and IBM). I haven't seen them on anything newer though.
I think the original purpose of those 6-pin connectors was for the theoretically large amount of power that you *could* draw with lots of expansion cards. I do remember an IBM manual calling it out for that situation, anyway.
PCI 2.1 allows each card to draw up to 25W, and does not specify any division of that load between the voltage rails.
There could be some commercial/industrial application where somebody could have 5 identical PCI cards all pulling near 25W each, and if a lot of that was coming from 3.3V then the amperage would be especially high.
Reply 19 of 22, by PcBytes
The only place I ever saw them used last was RDRAM based P4 and I think some early SDRAM based 478 boards (Aopen AX4Bs comes to mind). By the time 845 became standard it was phased out, as far as I remember.
