First post, by yk102
- Newbie
Hi! I bought a supposedly dead Toshiba T48050CT on eBay. It arrived dead as described with its original power supply. Trying a different power supply (1 volt above rating) made it work pretty much immediately and it booted straight into Windows 95.
It seemed to work wonderfully except for two problems:
- The audio didn't work. I couldn't hear a thing from the speaker or through headphones
- When under super intense loads, it would do this weird red artefacting on the screen. I've seen that exact symptom, with the same exact appearance, on another motherboard that needed a recap.
- The floppy drive seems to be dead. I can hear something spinning, but that grind sound from the heads is not there.
I took it completely apart today. No corrosion from leaked batteries or anything, so that's a big plus! The caps look okay.
Funnily, when I connected everything together (bare, without the shell to test that I didn't screw anything up) audio functionality came back to life magically. The only thing I did was reseat the little audio board.
I find this inconsistent behavior suspicious. Even more so because it doesn't work with its original PSU. I tested that with another laptop (a Compaq Armada) and it worked perfectly fine, so why isn't it working for the laptop its designed for?
It currently has ELNA electrolytic capacitors. I'm thinking of getting Panasonic FM-A Series capacitors since they have the exact values I need.
Thoughts? Here are some pictures mean while...
