First post, by rick12373
I am working on getting a Dell Dimension L866R up and running. The CPU socket is a PGA370. The old heat sink and fan was quite noisy so I replaced it with a new one I found in box which does fit and work but is also really noisy. Does anyone know if there is anywhere to buy a new heat sink/fan combo that would fit this and not sound so noisy? Maybe, I am spoiled by modern machines and their whisper quiet fans.
486 DX4-100 (overdrive)
16MB 72-pin SIMM RAM (2x8MB)
1MB Diamond Speedstar Pro VLB video card
SB 16 Value CT2770
AOpen VI15G Socket 3 Motherboard
HDD/FDD VLB controller card
Reply 1 of 12, by Pino
you can still find new heatsinks on ebay.
either search for PG370 or socket A heatsink, both should fit
Reply 2 of 12, by rick12373
Thanks. I was hoping to find one that is quiet. If anyone knows a model that is, let me know.
SB 16 Value CT2770
Reply 3 of 12, by Pino
quiet fans at that time wasn't really a big thing.
You can always replace the fan on one of the heatsinks you already have with a noctua fan
Reply 4 of 12, by Major Jackyl
Pino wrote on 2025-03-19, 22:10:
The heatsink most likely takes a 50mm fan... I WISH Noctua would make a 50mm. Last I checked, still no. Or 70mm.
I think the Dell has the room; for a 50 to 60 or 50 to 80mm fan adapter. I hope there is one out there. If not, I can dig mine out and share those (3d printable object, that is)
Most of the 50mm fans in my computers are whizz-b*tches, too, so I feel you on the noise. I have yet to concoct a 50/60 to 120mm adapter yet, but that will probably be the quietest (in whatever such a large adapter will fit).
Daily Units:
ASUS P55TVP4, P-MMX233, Matrox2064W, CT2770
ABIT IS7, P43.2(SL7E6), PNY6600GTS, Audigy(0090)
ASUS M2N-SLI, A64X2-5600+, EVGA 8600GTx2, Audigy2(0240)
ASUS ST-990FX, FX-8350, MSI GTX760x2, SB X-Fi(0460)
MSI Z690, i9-12900K, MSI RTX3090, SB AE-7
Reply 5 of 12, by rick12373
I have a big drawer full of fans and heat sinks. Maybe I can make something fit with a more modern fan on it.
This looks good but of course there is now way of knowing how quiet it will be.
https://www.ebay.com/itm/284413960941?_skw=PG … ABk9SR-i0joa2ZQ
SB 16 Value CT2770
Reply 6 of 12, by Grem Five
You can always use these https://noctua.at/en/na-src7 I have a few left over that came with some noctua fans I got a few years back.
I have also used some of these Chinese made ones and have had no problems with them but they always keeps me conscious of fire hazard when running them.
Reply 7 of 12, by rick12373
How about this for a fan?
https://www.amazon.com/Noiseblocker-ITR-XS-2- … 2/dp/B00839XK5W
SB 16 Value CT2770
Reply 8 of 12, by Major Jackyl
rick12373 wrote on 2025-03-20, 17:56:
Wow. 14Db @ 4000 RPM?!? That's not bad (dead-ass quiet even), if true.
8.8 CFM Ain't much, but fairly average for a 50mm. I kinda want to test one, too. I haven't bought a new 50mm since the early 00's.
I always liked the SUNON fans. Usually noisy, but have very high static pressure/high CFM.
Daily Units:
Reply 9 of 12, by rick12373
I ordered one. I will let you know how it goes.
SB 16 Value CT2770
Reply 10 of 12, by momaka
The problem with most socket 370 and 462 era hardware being loud is that the CPU fan is fed 12V all the time and not throttled in any way.
The easiest way to solve the loudness issue, at least for most socket 370 hardware, is to simply remove the grounding (usually black) pin on the fan and plug it into a 5V line, essentially making the fan run at 7V (12V - 5V = 7V difference). Just beware that there may be boards that check for CPU fan tachometer (RPM) output... so with the above suggested method, the tachometer usually stops working on most fans.
The second easiest method is to remove the positive (12V) wire from the fan connector and use a resistor in series to lower the voltage. With this method, the fan tachometer output will still work... and also, depending on what resistance you end up using for your resistance (20 to 100 Ohms tends to be the common range to get most fans quiet enough), you are free to set how loud you want your fan to be (at the expense of worse cooling and higher CPU temperatures.) Depending on how large the CPU heatsink is, one can make a nearly whisper-quiet rig or not so much. For the most part, stock Intel P3 heatsinks can have their fans run at half the voltage (6V) and still run plenty cool, even under 100% CPU load.
Now, as for socket 462, particularly the CPUs being quite a bit warmer than P3's, the above suggested ideas may not be achievable. But again, it all depends on how large the heatsink and fan is and also the CPU TDP. Low CPU TDP combined with a big-sized heatisink should allow for a good fan speed reduction (and this reduction in noise.)
Reply 11 of 12, by kotel
Socket 7 coolers also seem to fit on 462, although not sure if they do on 462.
An small and thin one from an K6-2 cools my 677mHz celeron without any issues.
I couldn't save them, but that doesn't mean I can't save myself!
Ready yourself!
Reply 12 of 12, by rick12373
By the way I did order the "Noiseblocker BlackSilent Fan ITR-XS-2-50mm".
It works perfectly. It is almost completely silent and moves a pretty good amount of air (easily enough for this CPU).
SB 16 Value CT2770
