Rendition Verite Thread
Reply 780 of 823, by Postman5
How to find out which point the conductors are connected to. On the memory chips you can see the connection with pin 45, this is A10
Reply 782 of 823, by y2k se
Can any owners of the original Rendition-ready ICR2 post the contents of the INDYFAST.BAT and INDYSAFE.BAT files?
I am trying to reconstruct them from my non-Rendition, retail boxed ICR2 and CART copies, but my CART version doesn't have these batch file equivalents. I think I was able to reconstruct enough of the INDYFAST.BAT from Re: Rendition Verite Thread in order to get DMA mode working, but would like to confirm their contents.
Tualatin Pentium III-S 1.4, ASUS TUSL2-C, 512MB RAM, GeForce 4 Ti 4200, Voodoo2, SB Live!, 3Com 3C905C, 80GB IDE HDD, Dell 2001FP
P233MMX, Intel LT430TX, 64MB RAM, Sierra Screamin' 3D, Voodoo2, AWE64 Gold, 3Com 3C905B, 40GB IDE HDD, Viewsonic A75f
Reply 783 of 823, by sharangad
y2k se wrote on 2025-03-23, 14:26:
I've modified these but these should be pretty close from Cart Racing:
[EDIT] To run on original hardware or with my wrapper, you don't need any environment variables, running cart.exe or indycar.exe will automatically run in DMA mode.
https://www.youtube.com/@sharangadayananda\
https://patreon.com/Rready
Reply 784 of 823, by y2k se
sharangad wrote on 2025-03-23, 14:41:
Much appreciated!
Reply 785 of 823, by sharangad
y2k se wrote on 2025-03-23, 14:45:
Much appreciated!
This environment variable controls dma. Set it to 0 for FIFO mode and 1 for DMA before running the game.
Set SPEEDY3D_DMA=1
For FIFO mode for icr2 you'll also need to set
Set SPEEDY3D=<path to icr2>
This isn't needed for dma mode or for any other Speedy3D game even in Fifo mode.
Reply 786 of 823, by y2k se
sharangad wrote on 2025-03-23, 17:13:
This environment variable controls dma. Set it to 0 for FIFO mode and 1 for DMA before running the game. Set SPEEDY3D_DMA=1 For […]
Much appreciated!
Set SPEEDY3D_DMA=1
I did some additional testing tonight. I'm using a patched ICR2 executable (to enable Cyrix support for Rendition) and it appears to run with DMA by default.
Reply 787 of 823, by sharangad
y2k se wrote on 2025-03-24, 01:27:
Much appreciated!
Set SPEEDY3D_DMA=1
Rendition ICR2 does by default.
Reply 788 of 823, by lepidotós
Is there a good way to make the V21/2200 slow down to V1000 speeds? I'm thinking of getting one and would like the ability to see how the V1000 runs things without paying more than I would for every other V2200 on eBay combined.
"I have to blow everything up! It's the only way to prove I'm not crazy!"
—Dr. Gordon Freeman, May 2000
Reply 789 of 823, by BaronSFel001
lepidotós wrote on 2025-05-03, 02:15:
Fair experiment, though if we go in that direction I would be interested in having V1000-native calls answerable by V2x00. I own Descent II and am interested in playing with 3D acceleration without having to compromise the cockpit view, plus EF2000 is another title of my interest. That, in my opinion, is the bigger issue when playing Rendition games made specifically for V1000 on a succeeding card; higher speed, if anything, would more likely be an asset.
System 20: PIII 600, LAPC-I, GUS PnP, S220, Voodoo3, SQ2500, R200, 3.0-Me
System 21: G2030 3.0, X-fi Fatal1ty, GTX 560, XP-Vista
Retro gaming (among other subjects): https://baronsfel001.wixsite.com/my-site
Reply 790 of 823, by lepidotós
BaronSFel001 wrote on 2025-05-08, 19:35:
Yeah, though in my case both would be nice to have, so as to compare the two directly. I assume both would be able to handle the same DirectX games as well, but I might be wrong on that. For just playing games of course the faster card is better and I'd even consider adding cooling to go even higher, but for cataloguing the differences in a controlled environment and not spending $500 it would have been good. I'm sort of surprised there's that much difference in general though, I'd have thought them both being programmable and everything I've heard of the V2x00 saying it's basically a superset of the V1000 would have meant it'd be natively doable, but I guess not.
Reply 791 of 823, by BaronSFel001
lepidotós wrote on 2025-05-08, 21:51:
V1000 was the original template for Direct3D and should be functional up to 5.2 (though I would not expect full feature support past 2.0). Like all devices with proprietary APIs, Rendition is best on what is tuned specifically for it.
Reply 792 of 823, by sharangad
Much appreciated!
Set SPEEDY3D_DMA=1
You should be also able to enable custom carsets by patching out 0x001B1000 (only occurs once in the entire file of the Pentium version) and replacing it with 0x00C04000 provided your machine has at least 64 MB of system RAM. The heaviest custom tracks are also possible if you use my GTREdit (https://youtu.be/mXPotS1o-os, link in description) tool on both carsets and tracks keeping the highest 5 mips maps for carsets and 4 for tracks.
Reply 793 of 823, by Nemo1985
It seems really impossible to find the original rendition v1xxx for a good price :\
Reply 794 of 823, by JustJulião
Hello, I've got two Canopus TOTAL3D V1000 cards a long time ago and finaly decided to attach one to a dedicated PC.
It's an overclocked Cyrix MII on a FIC VA-502. This platform was famous for being very fast for its price, but not so much in 3D. I figured it was a nice platform to get the most out of the V1000, since it is less dependent on the CPU's 3D performance than most other cards of its era.
The attachment IMG20250324134346.jpg is no longer available
The attachment photo_2025-10-19_10-57-42.jpg is no longer available
Since this thread focuses more on discussions about the second generation, I had trouble finding information.
- Can you recommend any games that make good use of this card? Apart from Tomb Raider.
- Has anyone managed to get overclocking to work reliably and keeping good compatibility with games with recent drivers?
Please, no comments on the act of overclocking itself. I know it's not rational, but getting the most out of vintage hardware is part of the fun for me.
Reply 795 of 823, by vetz
JustJulião wrote on 2025-10-19, 09:17:
You can see the whole list of supported games here for Verite cards. There are some that are worth playing:
Btw, you should take backup images of those games that came with the Canopus card, as those as far as I know are special versions for the 3D glasses that came bundled with some of the Canopus Total 3D cards.
Reply 796 of 823, by Postman5
Hi! I want to replace the V2100 with the V2200 on my Diamond Stealth II S220 graphics card. Has anyone tried this? I think these chips are very similar.
Reply 797 of 823, by Ozzuneoj
Hello, I've got two Canopus TOTAL3D V1000 cards a long time ago and finaly decided to attach one to a dedicated PC. It's an over […]
Very cool! I picked up a Total3D several years ago. Interestingly, I also found a 3rd party 3D shutter glasses kit called Nuvision 3D Spex that seems to use the exact same glasses as the Total3D (as shown in these pictures). I haven't had a chance to test the card with the glasses, but it's on my to-do list. It seems like 3D Spex kits show up somewhat frequently online, and I think some are listed for sale on the usual auction site right now (in the US though).
EDIT: That link to a Japanese Yahoo Auctions listing is probably not going to stay up forever, so I have saved and attached the pictures to this post for posterity. I don't think the Total3D used this packaging in the US, but the rest of the kit is probably very similar and the Nuvision glasses are even shown in the box art.
I Repeat: These are not my pictures, I do not own this stuff... sadly. 😀
Reply 798 of 823, by Postman5
Postman5 wrote on 2025-03-06, 23:43:
I think I figured out how to increase the memory to 16MB
Reply 799 of 823, by Postman5
Rendition Verite 16MB mod
