First post, by fosterwj03
I'm a bit stumped by this issue. Windows 2000 seems to run OK on my new (to me) Asus Prime H310-Plus motherboard with an i5-8400. My graphics card works in the x16 slot tied to the CPU and the OS sees the on-board PS/2 port (keyboard or mouse only), serial port, on-board network (if I can find a driver for it), and on-board audio. But, Windows 2000 fails to initialize PCIE-to-PCI bridges connected to the chipset's PCH regardless of if the bridge is on the motherboard (an Asmedia chip) or on a PCIE card in one of the x1 slots per my attached screen captures. PCIE bridges do work in the x16 slot connected to the CPU, so I think the issue comes from the PCH.
Windows 2000 see the bridges and appears to assign resources properly. Windows 2000 says that the BIOS doesn't provide enough information to initialize the bridges.
I tried to disable all of the PCH power management features which I read can cause bridge failures if the OS can't manage power reduction features, but that didn't change anything. I also tried several older versions of the UEFI/BIOS which also didn't seem to make any difference.
Windows 98, on the other hand, can initialize the bridges and the devices connected to them such as USB 2.0 controllers and my Sound Blaster Audigy.
Would anyone here at Vogon's know what might cause this error in Windows 2000? I have the same issue with Windows NT 3.51 also failing to initialize devices connected to the Asmedia bridge to the PCI slots (I suspect these errors are related). Is it possible that the board's UEFI/BIOS might have a setting that I've missed to fix this issue?
Thanks in advance.
