First post, by lazalius
Hello, i recently swapped out a P3 600EB for a 933.
BIOS works, memtest works, dos works, windows 98 installer works, safe mode works, but when I try to boot normal mode Windows 98 it freezes.
I reinstalled the os fresh, after the bootup it works for a short time, then when the PnP monitor setup wizard pops up, it freezes, or at least, keyboard and mouse freeze. Always at the same time. I suspect some kind of IRQ conflict but I don't know what to do.
From the bios i have the option for:
- Disable VGA IRQ
- Disable USB IRQ
- Assign IRQ to parallel/serial port
- Assign each IRQ to PCI/ISA PnP or Legacy ISA
- Assign IRQ to PCI slots
I'm on the following specs:
- Pentium III 933 MHz
- Soyo SY-6VBA133 MB with VIA Apollo Pro 133 Chipset
- 512 MB RAM
- Geforce4 MX440 AGP
- 80 and 40 GB HDDs
- PS/2 Keyboard and mouse
I can also boot to safe mode but I am not quite sure how to proceed troubleshooting the issue. I suspect the problem is the IRQ assigned to the new PnP monitori it finds at first startup, but the wizard can't be completed so the device isn't saved.
