First post, by Silver_Pharaoh
- Newbie
Hello everyone, first time posting here so apologies if this isn't the right spot to post!
I've recently acquired enough parts to assemble and install Win98SE on my retro gaming rig, I'll list the specs:
Abit BH6 (Had to repair bent pins in the slot 1 CPU Slot, seems to function okay albeit with a "nonworking cpu" error when overclocking)
Pentium III 500Mhz
ATI Rage 128 Pro AGP (PC Partners built?)
80Gb Seagate HDD
So what happens is whenever I boot up the PC, I see nothing on the monitor, but if I connect the VGA cable to the TV in the living room it displays the BIOS no issue (resolution reports as 720x400 @75Hz) Totally find once Win98 takes over the screen I can run programs and see the desktop no problem.
The monitor I am using is a modern day LCD, a Gigabyte G32QCA unfortunately due to space limitations I can't have a spot for a CRT, so I am using a VGA to HDMI adapter.
I've tried two different VGA to HDMI adapters, both the generic stuff from Amazon - one was USB powered the other had its own power supply and that one also converted component to HDMI of I wanted.
Is this just a case of too modern to use the old resolution? Or a cheap VGA-HDMI adapter? Side note, using the USB powered adapter I can display 640x480 without issue.
Can I change the BIOS & DOS resolution somehow?
