First post, by nclakelandmusic
Hey all, I'm getting my hands on a board with SB-Link, and I'm currently able buy these two boards mentioned in the title.
Which would you choose and why? I appreciate the insight.
Both are obviously Slot 1. It looks to me from the photos that the Gigabyte has an 800 mhz PIII, and the Abit comes with a 550mhz PIII.
Caps look ok on both boards, and the Gigabyte has two ISA slots vs the one on the Abit. Anything else you think I should know, for better or worse?
I'm leaning towards the gigabyte for the CPU and extra RAM it comes with as well as the additional ISA.
Reply 1 of 7, by PcBytes
BF6. ABIT used a much better clockgen than Gigabyte, and can do 133FSB with zero issues. I have its sibling with onboard Highpoint controller and it ran 133FSB alongside Geforce GPUs with no issues whatsoever. Its socket 370 counterpart is the BX133-RAID, as far as I know.
Reply 2 of 7, by nclakelandmusic
PcBytes wrote on 2025-03-26, 17:52:
Good to know. I just got this in from the Ukraine. I'm about to test it out right now in my other system and buy that board!
https://imgur.com/a/oyMlAq1
Reply 3 of 7, by PcBytes
Should definitely work. I have one as well and have had success with it on an ABIT BH6.
Reply 4 of 7, by nclakelandmusic
PcBytes wrote on 2025-03-26, 18:26:
Scored it, we shall see if it works. Thanks for the suggestion.
Reply 5 of 7, by Dan Solo
Its faster CPU and extra ISA slot could give you more room to grow later. The Abit board is fine too, but the Gigabyte just feels like it offers a bit more bang for your buck.
Reply 6 of 7, by shamino
A 550MHz CPU is most likely a Katmai.
Do all ABit BF6 boards support Coppermine voltages?
If not, then do you have a picture showing the voltage regulator IC (usually about 20-28 pins near the MOSFETs and caps next to the CPU slot)?
Reply 7 of 7, by PcBytes
BF6 is derived off BE6-II, except it trades the HPT366/370 controller for an additional PCI slot.
As for Coppermine voltages - it does. I have the BE6-II which the BF6 is based off, and it goes low enough for all kinds of Coppermines. I haven't got the required stuff to test Tualatins though.
