Reply 20 of 24, by Paddan1000
esher wrote on 2025-03-25, 07:15:
I've totally recapped my MT-32 too two years ago, and i must say all of the capacitors excepts two 1000uF in the power filter ne […]
I've totally recapped my MT-32 too two years ago, and i must say all of the capacitors excepts two 1000uF in the power filter near 7805 were good. These two was about 60-70% of capacitance.
But, anyway, i've changed them all.
Check for shorts after DAC and demuxer, analog audio circuit is not that big.
EDIT: ah, the problem was solved already. Good.
I've tested the four 1000 uF 16V caps that I desoldered from my board and they all were within spec at 969-978 uF and ESR 0,21-0,28.
Reply 21 of 24, by esher
Paddan1000 wrote on 2025-03-25, 19:56:
Nice! Are they Sanyo brand? All electrolythic caps on board that was within spec is Sanyo. I don't remember, which brand were those 1000uF.
P133/Marl/32Mb/CT2930/PicoGUS 2.1/MT-32/SC88 Pro/MU-128
Reply 22 of 24, by bloodem
Ozzuneoj wrote on 2025-03-25, 19:54:
Funny you mention that! I had a similar experience which I documented and created a whole thread about it:
Testing old caps with an ESR meter.
Yikes... that was seven years ago? Blegh.
That was a fun read! And, yeah, very similar to my experience.
2 x PLCC-68 / 4 x PGA132 / 5 x Skt 3 / 1 x Skt 4 / 9 x Skt 7 / 12 x SS7 / 1 x Skt 8 / 21 x Slot 1 / 8 x Slot A
Current PC: Ryzen 7 9800X3D
Backup: Ryzen 7 5800X3D
Reply 23 of 24, by Paddan1000
esher wrote on 2025-03-26, 07:19:
All of the old capacitors were Sanyo, the larger ones marked "CE" 85°C.
Reply 24 of 24, by esher
Paddan1000 wrote on 2025-03-26, 17:05:
Thats legendary caps. Very small amount of them lost their inital capacitance among years.
Anyway, i changed them all, because i worked on MT-32 digital output mod
- and some caps was on my way during installing DAC-FPGA board,
- and the rest was changed in "capschangin" fever
