First post, by marsV
I have the following questions about this CPU:
- Does anyone know this CPU?
- Can I run it on a GA-5AX 4.1, K6XV3+/66 B or PA 2010+?
- Can a standard S7 heatsink be mounted here?
- Is this CPU rare? (I think so, as I have few offers)
Thank you very much!
Reply 1 of 6, by marsV
In my opinion, the PA 2010+ has already been ruled out, as my research and the relevant CPU databases stipulate a core voltage of 2 volts
Reply 2 of 6, by marsV
Is there anyone out there successfully running this CPU on a Socket 7 system? 😀
Reply 3 of 6, by nickles rust
Here is a good thread about those:
Tillamook 266MHz and working L2 cache?
But for running a mobile chip in a desktop, I think the K6-2+ or K6-3+ are far better.
Reply 4 of 6, by marsV
I am a (Super) Socket 7 collector (not OC) and have an offer on this Tillamook TT266. K6-III+ 550 2V work well, yes, also the embedded version FV80503 1.9V is ok. I'm specifically interested in this TT266.
Reply 5 of 6, by bloodem
That CPU is for a TCP320 (laptop) socket. You won’t be able to use it on a socket 7 motherboard without some kind of adapter (not sure if that’s even a thing?)
2 x PLCC-68 / 4 x PGA132 / 5 x Skt 3 / 1 x Skt 4 / 9 x Skt 7 / 12 x SS7 / 1 x Skt 8 / 14 x Slot 1 / 6 x Slot A
Current PC: Ryzen 7 9800X3D
Backup: Ryzen 7 5800X3D
Reply 6 of 6, by marsV
Yes, its in package PGA320.
