ESS AudioDrive ES1868: no sound output at all?
First post, by jefklak
Hi all,
It's ben a bit of a rough ride here trying to get my vintage hardware working. I have a great genuine SB16 but since my old AT mobo broke I had to procure a "new old" one and that turned out to be a cheap Pine Technologies board that's leaky as heck. Result? the SB suddenly is super noisy. I "fixed" it with a Picogus, because I wanted to mess with it anyway, but the SB emulation is wonky at best.
And then I bought a ES1868, left it lying around for a few months, and finally tried it.
It does _nothing_. Literally nothing. So far I tried:
- 3 different drivers: Phil's lab, 2 different ones from Vogons. With one of them the Win3.1 setup did not recognize the card, the others work. Well, they recognize the card, ESSCFG prints the IRQ/DMA/mp4u port perfectly fine, and I can configure it fine, set BLASTER= in autoexec accordingly and DRIVER= load it in config.sys. Nothing.
- mixer settings: set all to max. Nothing.
- different boxes. Nothing. Replug in case I was stupid and did not select speaker output. Nothing.
- different software (win31 .midis, dos sb2.0 compat games, adlib games, older and newer games, games where sound _always_ works, ...). Nothing.
- contact spray. Nope. Other ISA port. Nope.
- add an S2 daughterboard and try waveblaster. Nope. Games like ROTT perfectly recognize and accept the setting but the output just isn't there?
I'm this close to crying here. Any other tips or stupid oversights on my account?
I'm not an expert in electronics so stuff like "decap that and resolder this" is a bit beyond my comfort zone.
The strange thing is, the card is recognized by the drivers and the games?
Thanks so much! 😊
Edit: this is the exact card (my photo, in attach)
Reply 1 of 21, by Grzyb
A photo would be nice...
Anyway, there's many possible problems, for example:
- some cards have jumpers to switch between LINE OUT and SPEAKER OUT (amplified) - if the jumper isn't installed at all, there's no output at all
- the amplifier chip may be dead - in this case you may still hear something in the noise that's heard when the volume is pumped to the max
- sometimes the software from ESS fails to work, but UNISOUND does work
Nie rzucim ziemi, skąd nasz root!
Reply 2 of 21, by Grzyb
OK, can see it now - it's a BTC.
The two jumpers near the output jack (JP4) obviously toggle LINE OUT / SPEAKER OUT - have you tried moving them to the other position?
JP3 must be the connector for MUTE, VOLUME UP, VOLUME DOWN buttons - if there's some short on the card, it may act as if the MUTE button is permanently pushed.
Reply 3 of 21, by bertrammatrix
Interesting. In my experience those ess cards are bulletproof, and 9 out of 10 times work right out of the box with whatever windows drivers they get. Even with wrong drivers. Even more interesting that you say that it is detected.
Have you tried all 3 ports? I have seen cards with mislabeled ports before (the tin piece could possibly be from a different card and the markings may not correspond)
Reply 4 of 21, by jefklak
Yes, I have tried all ports, see my initial post 🙃
More stuff I tried:
- BTC specific drivers from https://www.helpdrivers.com/sound/BTC/185x/ (turned out to be exactly the same and don't do anything special)
- vol up/down/mute jumpers
- line out/spkr out switch jumpers
- try random base addresses and IRQ/DMA combinations
Still nothing... Also dead silent when volume of the box is turned to the max.
Should I admit that it's broken?
Reply 5 of 21, by konc
jefklak wrote on 2025-03-31, 19:17:
It is very, very probable that this card requires -5V, do you use a newer PSU not providing it?
If you post a photo of the back side too, we'll tell you for sure.
Reply 6 of 21, by Trashbytes
konc wrote on 2025-04-02, 12:37:
It doesn't, only the very early sound blasters required -5v and some of the early clones.
I have several ESS 1868F cards and none of them need -5v its too modern for that.
Unisound works flawless with these cards .. if it doesnt it makes me think there is something wrong with the card or its hardware settings ...could be a wrong jumper or even a missing one.
Reply 7 of 21, by konc
Trashbytes wrote on 2025-04-02, 12:44:
No I insist, some do and I own one very similar to this that does. Anyway a photo of the back will solve it.
(Although mine wasn't completely silent but outputs really low volume, almost inaudible.)
Reply 8 of 21, by Trashbytes
konc wrote on 2025-04-02, 12:46:
No I insist, some do and I own one very similar to this that does. Anyway a photo of the back will solve this.
Thats not proof at all, mine have the -5v pin populated but it goes nowhere and does nothing since its not hooked up via any traces.
Reply 9 of 21, by bloodem
I have never seen an ESS card that requires -5V, and I've tested more than a hundred in the past years.
I am very interested to see high-res photos with the card you claim requires -5V.
2 x PLCC-68 / 4 x PGA132 / 5 x Skt 3 / 1 x Skt 4 / 9 x Skt 7 / 12 x SS7 / 1 x Skt 8 / 14 x Slot 1 / 6 x Slot A
Current PC: Ryzen 7 9800X3D
Backup: Ryzen 7 5800X3D
Reply 10 of 21, by konc
bloodem wrote on 2025-04-02, 13:05:
That's the card I own and have tested myself (now that I see it again I admit it's not that similar to the OP's, but still an ES1868F)
The attachment 1868F-5V.jpg is no longer available
There is another thread about the same card here which confirms it need -5V.
If this is not enough, first post contains a link to a photo of the back side which shows pin #5 connected:
The attachment 230X-3-ESS.jpg is no longer available
I'm not rushing any conclusions since OP hasn't replied yet and we don't know what his card looks like on the back side or what PSU he's using. Only that, based on his response, this can be a possibility since such a card does exist.
Reply 11 of 21, by PcBytes
I'd say the TEA2025 might be bad. I had to remove mine entirely and jumper the pads to use the internal amplifier from the chip, although mine was a cheap card that had no jumpers to switch between speaker and line mode.
Reply 12 of 21, by bertrammatrix
PcBytes wrote on 2025-04-02, 15:09:
I find that unlikely since there should definitely be output at least in one of the jumper positions.
However you never know, I've seen some really questionable things in the output sections of some of these cards, the worst of which was use of an output jack that shorted both signal pins to ground when disconnected, I'm sure the amplifier just loved a short circuit load.
If it was my card I would confirm the - voltage as mentioned. If that was ok I'd probably start poking around the output amplifier and see if there is any signal on it's input (an old headphone works well enough), as there should be signal there disregarding if the jumpers are set to speaker/line out.
I suppose it would also be possible that if the card was set to line out and got a voltage spike through that port that whatever op amp (if any) is between the ess and the TEA could have gotten damaged (or the ess's output itself), another reason to test for signal before the TEA
Reply 13 of 21, by bloodem
konc wrote on 2025-04-02, 14:28:
That's the card I own and have tested myself (now that I see it again I admit it's not that similar to the OP's […]
Thank you, I stand corrected. I’ve never had/tested such a card myself, quite interesting!
Reply 14 of 21, by RockstarRunner
I also have the same card konc has, and can confirm the -5v is connected
Reply 15 of 21, by nfraser01
Grzyb wrote on 2025-03-31, 19:37:
Anyway, there's many possible problems, for example: - some cards have jumpers to switch between LINE OUT and SPEAKER OUT (ampli […]
Or setting the mixer volume correctly?
Reply 16 of 21, by Grzyb
nfraser01 wrote on 2025-04-02, 20:02:
It seems set correctly:
...but it wouldn't hurt to try two independent programs for that, eg. ESSVOL and UNISOUND.
Anyway, at this point I'm more inclined to believe that the hardware is broken.
Reply 17 of 21, by jefklak
Apologies for the delay, here's a photo of the back of the card. Hope this will trigger some kind of hint...
Reply 18 of 21, by konc
jefklak wrote on 2025-04-16, 13:30:
One thing is certain, it doesn't need -5V. So as others have said, something is broken.
Reply 19 of 21, by jefklak
Things become even crazier. Now I'm suddenly able to get out some sound!! So jumpers are OK, so are the drivers.
But after 30 seconds the sound starts to drop off, then completely disappears. When I listen with headphones, you can hear a slight crack when I trigger something (e.g. a gun in a game).
I have no idea why it sometimes works but mostly does not. Oh well. I'll get another card 🙁
