Midi player for DOS? supporting SB1, SB PRO, SB 16, ADLIB, General Midi...
Getting old DOS games working. (DOSBox topics belong in DOSBox areas below, not here).
Postby franpa » 2008-4-21 @ 15:07
Is there a Midi player that works in the DOSbox environment that supports SB1, SB PRO, SB 16, ADLIB, General Midi?
Core i7 920 @ 2.66GHZ | ASUS P6T Motherboard | 8GB DDR3 1600 RAM | Gainward Geforce 560 Ti 2048MB PCI-E | Windows 10 Pro x64.
my website
franpa
Re: Midi player for DOS? supporting SB1, SB PRO, SB 16, ADLIB, General Midi...
Postby laxdragon » 2008-4-21 @ 15:18
I'm a fan of MegaMID. I use it with my MT-32, but I know it supports much more.
User avatar
laxdragon
Postby Zup » 2008-4-21 @ 15:43
I used Cubic Player. It was more like a "software synthetizer" (as Timidity), and it was able to render MIDI songs with the GUS patches and output to any SB.
I'm selling some stuff!
User avatar
Zup
Postby leileilol » 2008-4-25 @ 20:31
I remember some early demo versions of "Cakewalk" that was just a standalone DOS midi player, with a capability to play through OPL2/3 and also PC speaker. This is extremely hard to find now though, and only the midi CREATION (not playback) software is found.
so that's what it was called! Thanks! i've been looking for that for a while
Voodoo2s aren't 100mhz stock
Geforce256 isn't released as a beta on New Years '99 under the Quadro brand
DOS gaming isn't a bilinear 320x200 16:10
DOS PCs aren't better than the Macintosh
DOSBox is not for running Windows 9x
SGL != Glide
User avatar
leileilol
Postby fillosaurus » 2008-5-16 @ 21:06
There was one good ol' player called XTC. Worked with MP3's too, at least those ones with fixed bit rates (not VBR).
Voodoo box: Celeron 800 MHz, 512 Mb SDRAM, Voodoo 3 3000 AGP, 80 Gig Seagate, Yamaha OPL3 SAx 718+NEC XR 385, SoundBlaster Live!, NEC USB 2.0 PCI card.
WIP: external midi module based on NEC wavetable (Yamaha clone); VLB 486
User avatar
fillosaurus
Postby gerwin » 2008-5-17 @ 20:44
When you play a midi file with any such programs and output to an opl2 or opl3, does it need a conversion-bank or something to translate midi-instruments to opl waveforms? I Hope someone is willing to explain..
User avatar
gerwin
Postby Zup » 2008-5-17 @ 22:42
Something like that... a list of parameters to feed the opl2 and opl3 when playing the MIDIs.
Actually, Cubic Player "cheated" when playing MIDIs. It needed the patches from GUS and it converted the MIDI to waveform (like timidity does), and feeded to the DACs.
User avatar
Zup
Postby leileilol » 2008-5-18 @ 07:56
gerwin wrote:When you play a midi file with any such programs and output to an opl2 or opl3, does it need a conversion-bank or something to translate midi-instruments to opl waveforms? I Hope someone is willing to explain..
There's usually an instrument bank to do that. Most cases are usually GENMIDI.IBK files found generated from Voyetra apps
SGL != Glide
User avatar
leileilol
Postby gerwin » 2008-5-18 @ 23:02
Thanks for clearing that up
User avatar
gerwin
Postby gerwin » 2008-5-20 @ 11:07
It's not my topic, but I tried the above programs and it all works fine except they all lack one feature that need: playback of ordinary midi files through a hardware opl3 FM chip (with stereo output, not just using it as a mono opl2). I have googled a bit and tried about ten programs but no luck so far. The games themself can do it though?
User avatar
gerwin
Postby gulikoza » 2008-5-20 @ 17:13
I've played midis with win31 in dosbox. Not sure if it's stereo or not...
User avatar
gulikoza
Postby leileilol » 2008-5-20 @ 20:15
gerwin wrote: need: playback of ordinary midi files through a hardware opl3 FM chip (with stereo output, not just using it as a mono opl2)
MIDIER does OPL3, in stereo
gulikoza wrote:I've played midis with win31 in dosbox. Not sure if it's stereo or not...
The driver Windows ships with is OPL2. There is a OPL3 FM driver available for Win3.1 somewhere, and could even use custom instrument banks too iirc
SGL != Glide
User avatar
leileilol
Postby gerwin » 2008-5-21 @ 11:00
leileilol: MIDIER does OPL3, in stereo
Yes I tried that too, day before yesterday, why did I remove it though?
* downloads and tries program again *
Indeed stereo FM output!
I probably removed it because it appeared to me as such a messy program, it has some issues on my PC, I will give it a second look though.
leileilol: The driver Windows ships with is OPL2. There is a OPL3 FM driver available for Win3.1 somewhere, and could even use custom instrument banks too iirc
You mean this one maybe:
http://www.midiox.com/ \ Midi Tools \ Windows FM Synthesizer driver. (did not work for my Yamaha PCI card in windows 98... says 'no opl chip found', which is kinda understandable) Seems like a great tool.
User avatar
gerwin
Postby gerwin » 2008-5-22 @ 22:34
I tried some more programs and for now I am most pleased with these two:
MIDPAK, by John W. Ratcliff.
The full package can be found on the internet as Dmkit150.zip. It contains a lot of files all thrown in a single folder, drivers for all kinds of soundcards. Together with John Miles variants these drivers where behind the audio output of many commercial games.
Anyway Midpak's Menu.exe is a nice midi player, and with Setm.exe you can select between opl-3 or general midi or PC-speaker etc. For Opl-3 output it uses fat.opl as an instrument bank, which is designed by the 'Fat Man' as to resemble general midi instruments. I attached to this post the files necessary for using menu.exe as described.
GSPLAY v1.0 by Mark Fontana. The second program that impressed me today: Good interface (customized text mode), worked instantly, well documented, no-nonsense, single executable... Search for GSPLAY1.ZIP.
GSPLAY is a Standard MIDI File player for IBM-compatible computers
running MSDOS. The program has been specially designed for playing
General MIDI and Roland GS Standard MIDI files, but it will work fine
for non-GM/GS files as well. GSPLAY also includes special support for
the Roland SC-88.
midpak.zip
some midpak essentials from dmkit150.zip
to play midi files
(156.17 KiB) Downloaded 1639 times
User avatar
gerwin
Postby leileilol » 2008-5-23 @ 00:57
haha midpak is cool, pc speaker midi ftw!
SGL != Glide
User avatar
leileilol
Postby leileilol » 2008-9-25 @ 15:38
On topic again, i've finally found that Cakewalk demo again. I can't seem to get percussion channels to work though
CAKE5DMO.ZIP
Cakewalk for DOS 5.0 Demo
(450.48 KiB) Downloaded 1301 times
SGL != Glide
User avatar
leileilol
Postby alex.schroedsen » 2013-5-19 @ 14:29
I used to use Midier on my 386DX Packard Bell legend, it had a sound blaster pro 2, I still have the pro 2 actually. But I've recently been searching for a YMF262-M based sound card with the lowest Sound to Noise Ratio, the Microsoft Windows Sound System is where its at, 16bit 48khz ~90dB SnR Analog Devices AD1848 codec chip with a YMF262-M, the 2.0 driver does not allow the YMF262-M to be used in the windows midi devices but the 1.0a driver does. I am currently not able to play midis on the Windows Sound System device, just Adlib Tracker II and adplay etc. Because I have not been able to obtain the 1.0a drivers for the Windows Sound System or Midier. If anyone has either of these and is able to upload them, I would be very thankful.
alex.schroedsen
Postby akula65 » 2013-5-20 @ 14:28
HiTech Labs (home of Midier) can be accessed through the Wayback Machine:
http://archive.org
Just enter Tikbalang's links given above and go to the download page.
User avatar
akula65
Postby MaliceX » 2013-9-19 @ 16:43
Here's one no one mentioned.
http://retroworld.canell.dk/music/playe ... layer.html
The guy that made the driver for this DOS player also posted videos on youtube. eg:
http://www.youtube.com/watch?v=Vw9DJHVy ... aAmP40lqeJ
User avatar
MaliceX
Next
Return to DOS
Who is online
Users browsing this forum: No registered users and 0 guests
