Reply 1360 of 1892, by keenerb
Lostdotfish wrote on 2025-04-03, 15:45:Is there a known issue with PicoGUS and Doom in GUS mode? […]
Situation
I have a DOS 6.22 system with a YMF7xx card doing Soundblaster things and a GUS Max 1.8 doing Gravis music. They play together nicely and behave.
(Super Socket 7 VIA MVP3 Chipset - AMD K6-2+ @600MHz)SET BLASTER=A220 I7 D0 T4 P320
I have acquired a PicoGUS.
I removed the real GUS and installed the PicoGUS. Set it to use port 240, DMA 1, and IRQ 5 and replaced ULTRAINIT with PIGUSINIT
The PicoGUS initialises. Warcraft 2 setup menu detects the GUS and music tests fine.
Doom (and Doom 2) 1.9 both hang when loading with
GUS1GUS2calling DMX_INITSystem locks and a hard reset is required.
I also tested MIDIDEMO from the ULTRASND directory - this works fine with my real GUS. The PicoGUS results in
Error loading patch cymcrsh1: No response from DMA channelAgain, is this a known bug?
I was under the impression that this device had good GUS compatibility but so far it doesn't seem that way... or have I missed something in my configuration?
I don't believe playmidi works with picogus. I have the same DOOM behaviour with mine, although my gus pnp also doesn't behave properly...
