First post, by byte_76
I’ve extracted a BIOS image from the rom chip of my dead 486 motherboard.
Which application can I use to read the BIOS details from the BIN image such as the name, version, date etc…?
Reply 1 of 4, by Lostdotfish
Use any hex editor and you should be able to see the text strings
Reply 2 of 4, by Horun
If it is an Award compressed bios (signified by -lh5 in first line): Use 7zip to open and extract the original.tmp (or whatever is named inside) then hex edit it and you can read lots !.
Reply 3 of 4, by jakethompson1
The Retro Web has a bot in their discord that will take apart a BIOS that you upload (mostly to check if it's a duplicate, I think). I don't know if they have an offline version.
"strings" is a Unix utility with plenty of other ports (including Sysinternals for Windows) that just looks for printable strings in a file. That will give you the POST string, BIOS date, etc.
As Horun mentioned, Award BIOSes are parsable as an .LHA file to decompress them. For AMI compressed, there is a utility out there called AMIDECO.
Reply 4 of 4, by byte_76
Thank you for the feedback.
There seems to be an application called 86Box which can boot the BIOS. That's awesome, I'll definitely be looking into that.
