Reply 56500 of 58452, by Nexxen
My Ls-120 unit came in today.
It's as fast as 355KB/s and spinning ok.
One strange thing happened. I used W10 to test the unit as it just works, Linux can r/w but not format option (ok, there's a command but I was lazy), an d when I wanted to format the disk it was giving the defaults right off, but allocation size unit being on 2048 bytes made i stop at 75%. Had to select "default" on that too and it completed successfully all full formats. This value has to be set correctly, default points to the 512 bytes hence 2048 is wrong.
The noises are odd though 😀
I'm planning on recording the unit working sounds/noises to help any other poor soul out there. The more the merr... the less miserable 🤣
PC#1 Pentium 233 MMX - 98SE
PC#2 PIII-1Ghz - 98SE/W2K
- Bare metal ist krieg.
Reply 56501 of 58452, by PcBytes
Refreshing the thread with a few soundcards I got today.
- Audigy 2 ZS Retail (thanks to a few posts made by @Joseph_Joestar, I managed to figure it really is retail - SN is 0350 which means retail card)
- Ensoniq PCI Audio 5200 (with a Creative IC 🤣)
- CT4750 (SB 128PCI)
- SB AWE64 CT4370
- CMI8330A soundcard (which got recapped as soon as I got it, with polymers)
- an interesting MSI ball point pen
- 2x ARGB LED strips
The attachment 20250405_132256.jpg is no longer available
As well as another board added to the list by my contact, an Gigabyte GA-60XT-A.
The attachment IMG-20250403-WA0053.jpg is no longer available
The attachment IMG-20250403-WA0051.jpg is no longer available
The attachment IMG-20250403-WA0052.jpg is no longer available
Reply 56502 of 58452, by devius
PcBytes wrote on 2025-04-05, 15:46:
Looks good as new!
Reply 56503 of 58452, by PcBytes
I know it's not in the best shape but it's far better than some of the stuff I've been presented from him, there were a few boards that were pretty much goners. It's in need of a recap anyways so I could pretty much care less about the caps' state.
Reply 56504 of 58452, by pete8475
hah, years ago when I was selling computers in my shop Coolermaster Canada sent me a bunch of pens. When they arrived the ink was already dried out in them, so I called to start an RMA on the pens, needless to say the RMA department was very confused.
Reply 56505 of 58452, by flupke11
Compaq Presario 7462 in a quasi stock condition (K6/2 500, Mitac Camaro Via MVP4 mainboard, Seagate 8,4 GB disk). The system only ever received an update in the form of a black DVD-writer.
It might be one of those machines that sold in droves but are mostly forgotten nowadays. It's a good sturdy case, so I might use it to house a different MATX board (MS-6168?) or go with it as it is for DOS/early W98 games. I might pop in a K6 III and/or add a PCI Geforce MX card. Still unsure.
Reply 56506 of 58452, by Jccwu
Audician 32 plus
Sound card's music
Reply 56507 of 58452, by Nunoalex
Can you guys help identify this mysterious ISA card ?
It has a connect that looks like a printer port but this massive amount of chips, including an AMD 80186 ???? is a bit overkill for just a printer port no ?
I got is on a box of random hardware I bought at a local marketplace
thank you
Reply 56508 of 58452, by zuldan
Jccwu wrote on 2025-04-06, 15:54:
Audition 32 plus
Very nice. Apparently you could buy these new a couple of years ago. Are you going to do the noise filter mod?
Reply 56509 of 58452, by weedeewee
Nunoalex wrote on 2025-04-06, 16:13:
Can you guys help identify this mysterious ISA card ? […]
thank you
https://fcc.report/FCC-ID/IW4ATR/
Data Communications Controller Card
Dassault Electronique ATR
1991-03-13
the 1488 1489 chips make me think it's some kind of serial port.
Audition 32 plus
Looks to be Audician. Not audition
Do not ask Why !
Reply 56510 of 58452, by CMB75
Seems like I'm kinda on a losing streak lately. Bought a laser upgrade for my AMIGA 'tank' mouse to use in my A1000++ project only to realize that that upgrade does not fit into my original Hong Kong "BREMEN" AMIGA 'tank' mouse. Had to buy a different AMIGA 'tank' mouse from the bay. I have to do better ... next time.
Reply 56511 of 58452, by PcBytes
Currently no scores today due to awful weather, but looking forward the boards from the contact I have around next week.
Reply 56514 of 58452, by PcBytes
So that's what was missing on my YMF719E-S card. Interesting 😀
(it's exactly the same card (same FCC ID even) bar the built-in wavetable and IDE interface, and instead has a header for external wavetable.)
Reply 56515 of 58452, by devius
zuldan wrote on 2025-04-06, 16:15:
I remember when they were all the rage 10 years ago. I got one, but it's the model without built-in wavetable. What is this noise filter mod you mention? Can't find that particular mod. Just adding the IDE port and fixing the reversed stereo for the waveblaster port.
Reply 56516 of 58452, by devius
My guess is a SCSI controller card, but I've only seen Macintosh computers with that 25 pin connector. IBM compatibles usually use the full 50 pin Centronics connector instead.
Reply 56517 of 58452, by RandomStranger
It's been a long while that I bought anything other than notebook expansion cards and small quality of life stuff.
Today I found this and thought it's cheap enough that even if the board itself is dead and beyond saving, the CPU and the RAM still mostly compensates.
The attachment IMG_20250406_200343_HDR.jpg is no longer available
The attachment IMG_20250406_200319.jpg is no longer available
Naturally the seller claimed it was tested and working. I won't likely to have time to find out until next weekend.
Reply 56518 of 58452, by nfraser01
Made in 1992
Made by Dassault (the French electronics/aerospace company)
Optional ram upgrade installed (blue sockets)?
Might be another printer rasteriser, but potentially more interesting than that. Perhaps to connect to a Mirage 2000?
Reply 56519 of 58452, by Nunoalex
nfraser01 wrote on 2025-04-06, 18:41:
Made in 1992 Made by Dassault (the French electronics/aerospace company) Optional ram upgrade installed (blue sockets)? […]
Made in 1992
OMG a mirage ? 😎
So probably some knd of industrial card?
thank you now I have some lead to follow..
I installed it on a win98 machine and nothing was detected
