First post, by calvin
I'm looking for a sound card for my AlphaPC, which runs NT currently and I'm getting a SCSI card so I can run OpenVMS and Tru64. Currently, I have a SoundBlaster 16, which isn't ideal, as NT has drivers, but not VMS/Tru64 (That, and a real OPL is a waste in such a system.). What I do know is that both NT and the latter two support WSS sound cards (latter under what I suspect is the euphemism "Microsoft Sound Board"). However, my understanding is a lot of clone WSS chipsets can be quirky and require DOS initialization/custom Windows drivers or at least PnP stuff that I don't know would work. (NT at least has ISA PnP as a separate driver, and an unsupported ISAPnP variant of the SB driver.) What I'm looking for is cards or what to look for that shouldn't require anything beyond stock OS drivers. I do know the AD1848 (original WSS) and CS42xx chips (which I do know the Multia has an integrated one of these that works with NT w/ WSS drivers) should work, as might the CMI8330? ESS chips I've seen in the NT HCL explicitly called out as not supported in Alpha NT, but that might be with the special ESS driver only.
p.s.: Somewhat relatedly, I was looking at the Orpheus II LT and friends, since AC97 headers would be a nice bonus considering I built it into a modern case, but I'm not entirely sure about the story for init there. That, and they're not in stock anyways...
p.p.s.: I do know there are some NT drivers for high-end sound cards for NT, like Lynx and some Turtle Beach ones... it seems Alpha NT was a semi-popular target for DAWs; there's an Acid and Sound Forge port. I guess if your DAW outgrew x86 performance in the 90s...
2xP2 450, 512 MB SDR, V3 2000, Asus P2B-D, Windows 2000
P4 2.6, 2 GB DDR1, Radeon 9600 Pro, P4P800, Windows XP
Alpha 21164, 512 MB, Permedia 2, KZPCM, AlphaPC 164, NT 4.0
