Midnight Commander
Reply 21 of 46, by 7F20
marxveix wrote on 2025-03-26, 11:12:
Can you share it?
I don't think it exists. They are probably talking about norton commander, which is easy to find out there.
Reply 24 of 46, by liqmat
Just FYI. I did email the dev of the DOS version. They replied, but no longer have a copy.
Reply 25 of 46, by 7F20
Ah. I followed the breadcrumbs. Apparently the correct file is "mc146b.zip", but it doesn't exist anywhere I can see.
Reply 26 of 46, by zb10948
It is not some sick Linux on DOS fantasy, it is midnight commander code built with DJGPP.
It was probably totally straightforward because the version used is ancient - 1.4.6, it is one of the earliest versions just months into the projects' beginning.
And probably nothing alike the modern mc experience.
I used demos commander back then, didn't use the earliest mc's from mid 90s...
It would be theoretically possible to perform a static build of modern mc and all the dependencies using modern DJGPP. The resulting binary could end up at the size of Windows 3.11 installation...
Reply 27 of 46, by 7F20
zb10948 wrote on 2025-04-01, 22:09:
Jk jk.
I just thought it was funny that someone would go through so much trouble to make a DOS version of a Linux program that was itself made to give Linux users an version of DOS-only program (Norton).
Reply 28 of 46, by zb10948
7F20 wrote on 2025-04-01, 22:24:
Jk jk.
Heh. Put that way, it sounds funny, but I do believe it wasn't trouble at all. But I could put myself into trouble by building latest mc for DOS.
Reply 29 of 46, by 7F20
zb10948 wrote on 2025-04-04, 16:20:
I'm not sure how. MC is GNU GPL 3. You are free to do so.
Reply 30 of 46, by Alekokot
Sorry, my NAS was unavailable.
MsDos forever I have and use 386,486,P233,PIII700
Reply 32 of 46, by zb10948
It fails to load :
DPMILD32: dadvapi.dll: cannot load PE file
Reply 33 of 46, by Grzyb
I didn't try to run it yet, but I can already see I was right about this:
Grzyb wrote on 2024-01-02, 03:46:
the result would always feel like a "foreign body"
...because of the subdirectory named ".CEDIT" - illegal in pure DOS.
Nie rzucim ziemi, skąd nasz root!
Reply 34 of 46, by Falcosoft
Alekokot wrote on 2025-04-08, 12:37:
Both attached packages contain a Win32 PE executable version of mc.exe. None of them are valid DOS exe files.
But the 1st package contains files form HX DOS extender (HDPMI32.EXE, DPMILD32.EXE) that enables simple 32-bit PE executable files to run under pure DOS.
Website, Youtube
VST Midi Driver Midi Mapper
Reply 35 of 46, by Alekokot
I have this in stock, I don't have anything else, everything works for me
Reply 36 of 46, by liqmat
Falcosoft wrote on 2025-04-09, 04:49:
Alekokot wrote on 2025-04-09, 09:23:
Copied the contents of the HX DOS extender (v2.17) "bin" folder into the MC folder, adjusted the paths in "mc.bat" for my own convenience and away it went (in DOSBox). Cheers to Falcosoft.
The attachment mc_hxdos.jpg is no longer available
Reply 37 of 46, by Falcosoft
Of course it can work, even Win32 version of DosBox can run under pure DOS with the help of HX DOS extender. But this does not mean that Midnight Commander (or DosBox) has a DOS version. 😉
These are still Win32 PE executables written for Windows. You can use mc.exe from the attached packages even on 64-bit Win 10/11 natively.
Website, Youtube
Reply 38 of 46, by 7F20
Falcosoft wrote on 2025-04-09, 21:19:
According to this webpage: https://www.delorie.com/djgpp/v2faq/faq22_4.html
there does (or did) exist a DJGPP DOS version of MC. It may be lost to the world and the original owner was contacted about it already. I think the only shot at this point is for someone to recompile MC for DJGPP.
Reply 39 of 46, by Grzyb
I'm wondering if there's any value in porting MC to DOS...
I think there's only one feature that MC has, but similar programs for DOS lack - FTP client.
Obviously, there's a bunch of people craving for such a program - Anyone know a DOS FTP Client with GUI or shell
From what I can see, neither of the two Win32 ports (the one with HX DOS, and the one without) has that feature.
On the other hand, there's an FTP client in FAR.
So, is it possible to run FAR via HX DOS ?
And does HX DOS support networking?
