First post, by brynn
Hi!
Last year I purchased a Micron ClientPro (SE440bx2-atx) from a very nice man off craigslist. I have been played old CDROM games on it for a couple months now and generally enjoying it. Today, I went to turn it on, and it's showing its BIOS screen showing "RAM Passed" which is normal but then it's just hanging there, pressing keys doesn't do anything. motherboard lights and fans are not running. what happened here?
(i have built many modern PCs, and i work in electrical engineering, but i'm new to making old hardware behave and i forget what i would have done when i was a teenager haha. would love any advice!)
Reply 1 of 7, by wierd_w
It may be hanging trying to interrogate IDE drives.
Have you messed around in the cmos?
Reply 2 of 7, by cyclone3d
First thought is the HDD is dying / is dead.
That will happen when it is trying to read the drive, but it either is not spinning up properly or something has failed on the circuit board but not enough for the drive to not be seen at all.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 3 of 7, by Horun
Agree ! Most likely a failing drive. Try going into bios and disable the HD controller and set it boot to floppy first if it is not. Save a reboot and it should try to boot from a floppy disk...
Reply 4 of 7, by Major Jackyl
I concur with the HDD issue. If it's getting stuck stuck, pop'er open and unplug the HDD, then try booting, see if it will make it through POST completely. If still no, we have another problem.
Are you sure the fans don't run? If we're seeing POST, at the very minimum, the PSU fan should be going. If not, we should start with that.
I'm guessing this computer had a distinctive fan whirr that's not there anymore?
Must open it, whatever the matter is.
Main Loadout (daily drivers):
Intel TE430VX, Pentium Sy022 (133), Cirrus Logic 5440, SB16 CT1740
ECS K7S5A, A-XP1600+, MSI R9550
ASUS M2N-E, A64X2-4600+, PNY GTX670, SB X-Fi Elite Pro
MSI Z690, Intel 12900K, MSI RTX3090, SB AE-7
Reply 5 of 7, by BinaryDemon
Hard power cycle? Remove power cord, press power button to de-energize any capacitors , plug power cord back in as try powering on?
Next I’d look to try and reset the cmos. Clear cmos with jumper or removing battery. Restore defaults and re-apply bios settings.
If still no luck it’s time to start looking at components, like ram/power supply.
Reply 6 of 7, by BitWrangler
Micron were using Intel made motherboards I think, so looking up problems specific to that board model may be helpful.
Reply 7 of 7, by brynn
thank you all for the suggestions! i had never opened the tower before, and a very strange thing i noticed is that it actually doesn't have an SDD inside it?? the OS is running off an SD card. (yes, there's an added SD port card in the motherboard) i'm remembering now that it would ask me "boot from [DRIVE]" everytime i started it up. i'm surprised it was able to install games on the computer at all! luckily, the nice man also gave me a "extra" SDD so i will install it and let everyone know what happens tomorrow 😀
