First post, by Luger
Hello!
Could you help me with the game "The Legend Of Dragon's Son"? I can't get it to run properly with any wrapper. With DgVoodoo2 too 🙁
Here is the link: https://mega.nz/file/3EoQVIrT#Qufak7p5fmgvBlw … MeG0KXj0euqyXCw
Thanks in advance!
Reply 1 of 5, by BEEN_Nath_58
Did the game break in DxWnd (so that it is revised)? Or you want to run it with a wrapper directly?
Reply 2 of 5, by Luger
BEEN_Nath_58 wrote on 2025-04-08, 12:44:
I want to check if there are other ways.
Reply 3 of 5, by Luger
DgWoodoo2 works if you add entries to the registry https://raw.githubusercontent.com/narzoul/DDr … Redirection.reg
But the game has a serious problem, at the very beginning of the game, after the dialogues, the battle should begin, the game goes to the battle screen. And then something strange happens.
If this can be somehow fixed, I would be just happy!
Reply 4 of 5, by Dege
I looked into it and I know what the problem is, but unfortunately I cannot fix it now. The same frame is simultaneously rendered with DDraw/D3D8.
It requires some development in dgv, which I've been planning for a while, but at least now I have a real test application for that.
Reply 5 of 5, by Luger
I really hope that in the future you will fix this 😀 I will wait with impatience!
