First post, by Maz Hoot
- Newbie
Hello, I’m still in my quest of a decent laptop for adlibtracker2. It went good on toshiba satellite 320cds but the screen was garbage and the speaker didn’t work, and I can have headaches migraines easily (about the screen). So I found a toshiba satellite pro 4300 in good condition.
I’m on Freedos, it may seems weird but I had to change the disk on the sat pro 4300 and I had one with Freedos and all my stuff, and I’m use to it so if it’s possible I would like to continue using it.
USB problem : I use USBASPI.SYS and DI1000DD.SYS in FDCONFIG.SYS , I have an old usb key which was good recognized and used on toshiba s320cds and tecra530cdt in freedos too with same driver. But on the pro 4300 it says target usb device not found… I have an other usb which is found and is 4Go but on this second one it says : #1 : ??? 4026MB drive = D: Not format and I can’t access to it… I tried format it again in fat32 but same error…
Hot problem : Freedos is probably really not too much for this computer, but after 3min of use, the fan turn on very quickly and it’s a little hot just under the place where the power supply is plugged. I tried an other power supply so the problem does’t come from here… I think it’s not suppose to be hot or have fan running so fast when i’m just in the freedos command line doing nothing…
Graphic/character problem : the screen is small, a rectangle in the middle, if I stretch it from bios, it’s not beautiful and under adlibtracker 2 character are weird… under toshiba s320cds I used vexp for resolve this. Is there something similar for the toshiba sat pro 4300 ?
My music (chiptune, post-punk, world, industrial) : https://mazhootmusic.bandcamp.com
