Reply 1380 of 1892, by StriderTR
After much consideration, perusing this thread, and arguing with myself back and forth far longer than should've been necessary... The deed is done.
I've decided to replace the AWE64 Value and Opti 82C920 in my DOS 6.22 build with the PicoGUS. The wide range of games I'm using on that system would benefit from having GUS/SB/AdLib support to pick from on the fly. Also, much easier than running multiple cards (and cheaper). Lastly, I just want to play with it! Don't get me wrong, I love the AWE64 and Opti, but the PicoGUS seems like it will make life a bit easier on that build. We will see.
Wish me luck! 😀
DOS, Win9x, General "Retro" Enthusiast. Professional Tinkerer. Technology Hobbyist. Expert at Nothing! Build, Create, Repair, Repeat!
This Old Man's Builds, Projects, and Other Retro Goodness: https://theclassicgeek.blogspot.com/
Reply 1381 of 1892, by vutt
In case of anyone having problems with VIA Apollo Pro 133T (VT82C694T) MBs here is what I observed and how I managed to fix it.
I have QDI Advance 10T and in MSDOS 7.10 mode card worked partially. Doom and Dope by Complex dos demo - no sound, while second reality by future crew dos demo and cubic player worked just fine.
Solution: reserving picoGUS IRQ and DMA resources in BIOS for Legacy ISA. Never had similar issues with 440BX or older boards where AUTO always worked.
Reply 1382 of 1892, by Pickle
StriderTR wrote on 2025-04-12, 17:43:
Wish me luck! 😀
I’d keep the awe 64 and with unisound configure it to different resources then you have the sb16 and awe midi support with the pico.
Reply 1383 of 1892, by Linoleum
Pickle wrote on 2025-04-14, 12:36:
Wish me luck! 😀
I agree... AWE64 + PicoGus is a great combo to cover early DOS (CMS, GUS, AdLib with the Pico) and late DOS (SB16, AWE32 with AWE64).
P3 866, V3, SB Audigy2
P2 400, TNT, V2, SB Audigy2 ZS
P233 MMX, Mystique220, V1, AWE64
P166, S3 Virge, SB32, PicoGus
486DX4 100, CLGD5424, SB32
Prolinea 4/50, ET4000, SB16
SC386SX 25, TVGA8900D, Audician32
286 10, ATI VGA, Forte16
PS2 30/286, SBP
Reply 1384 of 1892, by dukeofurl
Has anyone had issues with using the picogus on a PC with the xtide bios? I saw a cryptic reference to that many pages back in this thread and was curious to learn more.
Reply 1385 of 1892, by Pickle
dukeofurl wrote on 2025-04-14, 19:34:
just the universal bios or the xtide hardware as well? I just ran a picogus 2.0 hw with the universal bios in a nic.
Reply 1386 of 1892, by MadMac_5
Linoleum wrote on 2025-04-14, 18:20:
Wish me luck! 😀
I also agree; I've used the two of those as a pair, and it was wonderful. The PicoGUS also works great as a way to use MIDI daughterboards like the X2GS with an AWE card and avoid Creative's buggy MPU-401 implementation. That setup let me play TIE Fighter with SB 16 sound effects and X2GS music with no stuttering or hitching, which was an amazing experience! One can also use the PicoGUS alone as a GUS for digital sound with the MPU-401 for music.
Reply 1387 of 1892, by Sly_Botts
I also decided to purchase a picoGUS. I have an Asus p2b mobo with an audigy PCI for win 98 and an ensoniq soundscape s2000 and sb16 ct2800 for DOS 6.22. I've removed the ct2800 in preparation.
I'm wondering if they plan to eventually integrate mt-32 emulation for those who have the ROM files. That would be awesome.
It is possible to commit no errors and still lose. That is not a weakness, that is life.
Reply 1388 of 1892, by Pickle
Sly_Botts wrote on 2025-04-18, 16:36:
there are mt32-pi in wavetable form that can do this
Reply 1389 of 1892, by dukeofurl
PSA, I tried using the GUS pro patches 1.61 today and in my experience I needed to use a version of the patches that was designed to work with dosbox for them to play correctly. I didn't extensively test and tweak things, but quickly testing out the regular version of the patches with the picogus resulted in samples looping/continuously playing, which doesn't happen with the modified patches. The looping samples situation seems to be an issue people using dosbox have identified when trying to use the regular version of the patches.
This old thread provides both sets and a comment about the dosbox looping issue.
Gravis Ultrasound Driver Package
Reply 1390 of 1892, by Sly_Botts
Pickle wrote on 2025-04-18, 16:39:
Are you talking about the mccake daughterboard?
Reply 1391 of 1892, by Pickle
Sly_Botts wrote on 2025-04-19, 00:36:
yeah thats a commercial version. Scrap computing (youtube) made a pcb that ive used personally and Bits und Bolts (youtube) has a spin based on scrap computing version. So if your able to order pcb's and solder they can be made for about $30.
Reply 1392 of 1892, by Sly_Botts
Pickle wrote on 2025-04-19, 00:57:
Nice!
Reply 1393 of 1892, by Sly_Botts
I just think it would be perfect but the pico isn't powerful enough to emulate mt-32 which it is what it is. However if someone made a daughterboard that only does mt-32 emulation for a decent price that would be mint.
Reply 1394 of 1892, by Pickle
Sly_Botts wrote on 2025-04-19, 15:20:
right the pi pico can not, but the wavetable boards use pi zero 2 which are powerful enough. Or you can build an external module with a pi 3 or higher.
Reply 1395 of 1892, by polpo
Hi, I seem to have stopped getting notification emails from Vogons, sorry for missing so much activity on this thread! It seems everyone with issues had them resolved but now if people reply I should actually notice them... 😅
creator of PicoGUS and PicoIDE
Reply 1396 of 1892, by Sly_Botts
polpo wrote on 2025-04-19, 22:54:
Thank you so much for making this product, I can't wait for it to arrive! I like the idea of the clean output. My SB 16 midi/FM volume was causing lots of noise. its going to sound so nice! Thanks for adding SB emulation as well. My soundscape s2000 isn't the best for SB emulation.
Reply 1397 of 1892, by NeoG_
I figured you needed a break from the project since the card went ready-to-run commercially on serdashop and so much feedback has been generated.
It's tough because so much of people's issues are just plain old IBM PC resource management.
98/DOS Rig: BabyAT AladdinV, K6-2+/550, V3 2000, 128MB PC100, 20GB HDD, 128GB SD2IDE, SB Live!, SB16-SCSI, PicoGUS, WP32 McCake, iNFRA CD, ZIP100
XP Rig: Lian Li PC-10 ATX, Gigabyte X38-DQ6, Core2Duo E6850, ATi HD5870, 2GB DDR2, 2TB HDD, X-Fi XtremeGamer
Reply 1398 of 1892, by appiah4
It's fine as long as you are busy developing the project 😉
We got dis. 😁
Reply 1399 of 1892, by Sly_Botts
I do have a question if someone can help. If I want to use an mt-32 with the picogus, do I need to set it to MPU-401 mode? Is it possible for it to emulate the Gus while also using the midi out? Or is it just one or the other?
