First post, by Kubik
Folks,
I found this weird expansion card in my Toshiba T5100:
I am guessing this is some kind of expansion interface cards, like some sort of a docking station, but I could not find any more details.
Do you have any info on this one?
Thanks a lot!
Reply 1 of 3, by Thermalwrong
Kubik wrote on 2025-04-14, 15:09:
Folks, […]
Folks,
Thanks a lot!
Hmm, I thought it was for the desk station II which was the dock for the T5100 series but no, it seems to be a PA7313E expansion chassis card - see the parts list here:
https://conventionalmemories.com/TECHaccess/tech5228.htm
Mentioned & priced in an old magazine:
The attachment Screenshot 2025-04-14 at 16-40-10 Radio-Electronics-1991-01.pdf.png is no longer available
This website has a picture of the chassis with the cable:
https://spwindustrial.com/toshiba-expansion-b … -module-6-slot/
The attachment 221189075809__66999.jpg is no longer available
Worthpoint has some good pictures archived including the internals of the chassis:
https://www.worthpoint.com/worthopedia/toshib … e-pc-3845869308
The attachment 1_bab9a071f3718dd60f4ffdd55f336cfa6.jpg is no longer available
They're 8-bit slots? Apparently maybe this was from when the T1100 was around so perhaps 16-bit wasn't so important/possible then.
And a T3100 that included the expansion chassis:
https://www.worthpoint.com/worthopedia/vintag … able-4574851471
The attachment 1_f4297015c70567418378d7170e37c3882.jpg is no longer available
Ooh and I found the parts diagram in the Toshiba ATLAS software, your card is part 16 - specifically the one for the T5100 😀
The attachment atlas-pa7310u-partslist.png is no longer available
Reply 2 of 3, by Kubik
Oh, thanks, that's awesome! My card says FEXPTR and I can see that mentioned on the last image.
Those are apparently 8-bit ISA slots so I guess Toshiba either didn't see any need for 16bit cards, or they wanted to keep things backward compatible with T1100, or they were planning another expansion box with 16bit connectors.
Anyway, good to know! I could reverse engineer the card, but it's probably not worth the effort as the connectors are no longer available. Well, they are available if you are willing to buy 200 of them (5 bucks each) which is out of my budget 😀
Reply 3 of 3, by Erodros
Just to add to this. I managed to get a hold of this box when I bought a T1200 that had that same weird connector and card. A DSUB 100 I think? I have to dig it out. Anyway that upgrade card looks similar to the one in my T1200 (It also fits in the T1100 too). Basically the PJ1 connector is the 8 bit bus and it just feeds directly into the cable to the box. Believe it or not there is an off brand one somewhere but I just have the adaptor card. Seems like that one uses a ribbon cable of some kind and clamps that hook to the bottom of the laptop but still having finding part info.
