First post, by Rob Hubbard
Hi, I am currently trying to reproduce the PC speaker sound from old games using dosbox.
So far I have managed to capture the frequencies from pcspeaker.cpp (PCSPEAKER_SetCounter), and the ticks between each "tone". But I can't seem to find the duration of the pauses in between the speaker tones.
Any help / suggestions would be much appreciated.
Reply 1 of 4, by Snejs
Offtopic:
Rob Hubbard? THE Rob Hubbard or only a fan of his music?
Reply 2 of 4, by Qbix
Rank DOSBox Author
DOSBox Author
can't you just save the writes to the ports in question ? (e.g keyboard port and timer port ?) PIT_Fullindex() gives you a millisecond float which you can use to determine the time of the writes.
Water flows down the stream
Reply 3 of 4, by Rob Hubbard
Thanks for the tip. I already obtain these values from PIC_TICKS in PCSPEAKER_SetCounter. The problem is that each 'tone' lasts until another tone begins. (I can't find the timings for the pauses inbetween.)
Reply 4 of 4, by wd
Rank DOSBox Author
DOSBox Author
I'd assume pauses are when the speaker is turned off, or am i missing something??
