First post, by jmej_jmej
I recently scored a machine based around an ECS UM486V. It has 2 floppy drives and a cdrom all chained off of a CT1770 (sb16 SCSI)
currently it has no internal storage and I'm trying to figure out what the best approach is.
Should I look for a SCSI hd (maybe 2gb) and add it to the chain? Or get an ISA or VLB ide card? or... some other idea I haven't thought of?
I have an ide CF I wouldn't mind using, but I also don't mind tracking down an old scsci disk.. im mostly unsure if adding to an already significant scsi chain is a good idea, or if adding an ide controller would lead to too many potential device conflicts or some other issue.
Fwiw it has 2 vlb slots, 1 open and 1 with a video card, and a handful of free isa slots.
Reply 1 of 9, by Disruptor
I don't think your CT1770 has a SCSI BIOS, so it won't boot from any drive connected.
The CT1770 has no floppy connector.
Can you tell us where your floppy drives are connected to?
Reply 2 of 9, by jmej_jmej
Ah interesting! It's possible that they aren't connected to anything.. this is a project that is currently in transit to me - I might be trying to plan ahead a little too much since I haven't laid eyes on it yet. I'm basing all of my assumptions a couple of ebay photos - but its been fun trying to trainspot the situation. I'll certainly post a follow up when I get the system but if you're interested in playing along I'm attaching the photos. It was a good deal with very little information so I'm expecting a project!
Reply 3 of 9, by jakethompson1
Looks like you've got onboard I/O. You probably have onboard IDE too, or at least a strong enough chance to wait for the system to come before buying anything.
Reply 5 of 9, by Lylat1an
If you don't have an onboard hard drive connector, I'd advise an XT-IDE device.
They plug into an ISA slot and give you bootable IDE and CF connectors.
Reply 6 of 9, by BinaryDemon
SCSI floppy drives are a thing, but pretty rare.
I’d guess from the low quality pictures that the floppy drives are connected to motherboard, and that it’s just obscured from view.
Reply 7 of 9, by dionb
jmej_jmej wrote on 2025-04-18, 07:30:
It's certainly possible - but the board looks a lot like this to me: https://theretroweb.com/motherboards/s/ecs-um486v
My eyes are getting too old for the kind of potatocam thumbnails posted here, but I'm pretty sure this isn't the board - if it were there would be 30p SIMMs above the top ISA slot, immediately behind the AT DIN connector. Not sure what is there (I see a few onboard chips...), but it doesn't look like SIMMs to me.
If you can't get any better pics/clearer ID of what you are getting, wait until you actually have the hardware and can figure this out before deciding on storage.
In any event I wouldn't recommend XTIDE or SCSI from the SB16 as that would bottleneck it badly by 8 or 16b ISA bus. If there's no onboard I/O I'd go for a VLB controller; IDE would be simplest, with a passive IDE-CF adapter. But again, there might be VLB I/O onboard. Wait and see.
Reply 8 of 9, by chinny22
SCSI is pointless in this day and age, outside very specific cases, eg old servers.
Hard drives are ancient and probably seen heavy 24/7 usages from servers and SCSI2SD is expensive.
IDE hard drives are also pretty old but far more common but IDE to CF or SD card adapters are much cheaper and will give very similar performance.
IMHO stick with IDE unless you really want to play with SCSI just for the fun of it.
I'd also go with a VLB controller, it's kind of special and price are not as inflated as VLB video cards
Reply 9 of 9, by PC Hoarder Patrol
dionb wrote on 2025-04-18, 11:25:
My eyes are getting too old for the kind of potatocam thumbnails posted here, but I'm pretty sure this isn't the board - if it w […]
Thinking it might be this one (ECS UM486V AIO )... https://theretroweb.com/motherboards/s/ecs-um486v-aio
