Reply 160 of 223, by Googolplexian
Can I use the ARM64_CHPE_x86 builds for a x86 game? I tried usind these .dlls in NFS Porsche and it didn't start. These builds are for a ARM CPU only? I have Ryzen 7 9700X.
Googolplexian wrote on 2025-03-26, 21:32:Can I use the ARM64_CHPE_x86 builds for a x86 game? I tried usind these .dlls in NFS Porsche and it didn't start. These builds are for a ARM CPU only? I have Ryzen 7 9700X.
Arm is for arm cpu only, yes, 🤣. You need files from x86 folder.
Yes, but only on ARM cpu's.
A little WIP:
WIP97
Changes compared to v2.85
http://dege.fw.hu/temp/dgVoodooWIP97.zip
http://dege.fw.hu/temp/dgVoodooWIP97_dbg.zip
I release the current state because I won't have time for dgVoodoo in the near future:
v2.86
http://dege.fw.hu/dgVoodoo2/bin/dgVoodoo2_86.zip
http://dege.fw.hu/dgVoodoo2/bin/dgVoodoo2_86_dbg.zip
I release a patch version for 2.86:
v2.86.1
http://dege.fw.hu/dgVoodoo2/bin/dgVoodoo2_86_1.zip
http://dege.fw.hu/dgVoodoo2/bin/dgVoodoo2_86_1_dbg.zip
SurRender is a Wizardry 8 engine, i presume? But what in the world is Pornstars 🤣, is this some obscure 3dfx adult game?!
KainXVIII wrote on 2025-04-19, 08:33:SurRender is a Wizardry 8 engine, i presume? But what in the world is Pornstars 🤣, is this some obscure 3dfx adult game?!
https://www.pouet.net/prod.php?which=5954
It seems to have the same engine as SurRender, with various backend renderers (Glide2/3/DX/OGL).
I can't fix problems quickly, so I release a WIP for the pending fixes:
WIP98
http://dege.fw.hu/temp/dgVoodooWIP98.zip
http://dege.fw.hu/temp/dgVoodooWIP98_dbg.zip
I released a patch version for the cumulated fixes:
v2.86.2
http://dege.fw.hu/dgVoodoo2/bin/dgVoodoo2_86_2.zip
http://dege.fw.hu/dgVoodoo2/bin/dgVoodoo2_86_2_dbg.zip
Dege,
Just wondering if you might like to take a look at Mechwarrrior2 and see if there's anything you think might be fixable on your end.
To be clear, it works, but it sometimes shows objects through others, and occasionally the graphics are screwy on mission start.
Installer which works fairly well but is stretched by default: Re: A comprehensive guide to install and play MechWarrior 2 on new versions on Windows.
dxwnd/dgvoodoo config for 4:3 resolution which occasionally glitches: Re: A comprehensive guide to install and play MechWarrior 2 on new versions on Windows.
I played MW2 Titanium Mercenaries, specifically (since there are ~40 variants:
CD label: TITAN_MERCS
product.ini-productid: TITMERW95
product.ini-productname: Mercenaries Titanium Edition
Again, it mostly works, and I have only had it obviously fail at the start of a mission which is easily solved by loading from save.
Cheers for any insights!
I built:
Dege
Once you have time, can you please experiment into making WinG32.dll/WinG supported API games work with dgvoodoo2? just for the sake of making Warhammer: shadow of the horned rat work without forced 640x480 fullscreen? the dxwnd solution became quite outdated after the GoG preservation update.
In fact kinda want BEEN_Nath_58 to help you with this too since verok managed to make his own take for HOMM 1-2 and the source code was preserved at the archive website for safety.
Also, no problems with Warhammer Dark Omen yet.
Deffnator wrote on 2025-05-29, 15:28:Dege Once you have time, can you please experiment into making WinG32.dll/WinG supported API games work with dgvoodoo2? just for […]
Dege
In fact kinda want BEEN_Nath_58 to help you with this too since verok managed to make his own take for HOMM 1-2 and the source code was preserved at the archive website for safety.Also, no problems with Warhammer Dark Omen yet.
Hi, can you explain a bit about the GoG preservation update, as to what changes you faced?
BEEN_Nath_58 wrote on 2025-05-29, 17:15:Deffnator wrote on 2025-05-29, 15:28:Dege Once you have time, can you please experiment into making WinG32.dll/WinG supported API games work with dgvoodoo2? just for […]
Dege
https://www.gog.com/en/game/warhammer_shadow_ … _the_horned_rat
check the improvement changelog below from the preservation update
1.0 GOG v4 changelog: Improved compatibility with Windows 10 and 11 so the game runs smoothly on modern setups. Added a WING wra […]
Added a WING wrapper to boost graphics rendering and fix visual glitches.
Introduced a new MIDI music player for better audio quality and fewer hiccups.
Fixed those frustrating game freezes during the loading screen.
Shortened long loading times: less waiting, more playing.
Cloud Saves are now supported to keep your progress backed up and ready to go.
Stability validated.
I'm using dgVoodoo v2.86.2 - for regular usage (re-released: 2025.06.29)
but windows defender is popping up Trojan:Win32/VBClone!rfn on dgVoodooCpl.exe
idk what program to do crc32 or sha256 check but
size 399kb (409,088 bytes)
Size on disk 400kb (409,600)
I saw a recent complaint with 404 on the website. Can you confirm that this is expected, and that the website, or more specifically the download, has not been hacked?
Just as a test I downloaded 2.86.1 (the previous version) and it's not popping up for any virus.
Getting 404 when trying to download the latest and previous builds from both the forum thread and the homepage
Dege can you add affinity core option in wrapper? For example other wrappers (cnc-ddraw, DDrawCompat, dxwrapper) have similar feature. Some games desirable start on single core. Plz))
mitradis wrote on 2025-07-10, 12:14:Dege can you add affinity core option in wrapper? For example other wrappers (cnc-ddraw, DDrawCompat, dxwrapper) have similar feature. Some games desirable start on single core. Plz))
I always support more options, thus this option.
I'm almost certain that I recall that you can make a batch file (start with text editor and save as .bat instead of .txt) with a line to launch an executable with set affinities. You could even make a shortcut to the batch file, and use the icon of the game so launching it feels more natural. This obviously isn't anywhere as convenient as a setting is dgVoodoo2's control panel, but it can work as a temporary workaround without having to use msconfig -> boot tab -> Advanced options... -> Number of processors: 1. However I have seen some games not work with affinity and having to launch the computer with 1 processor anyways.
Lemonzest wrote on 2025-07-10, 07:21:Getting 404 when trying to download the latest and previous builds from both the forum thread and the homepage
I could email 2.86.1, 2.85, or 2.84.1 . For some reason 2.86.2 is popping up for a tojan virus, while 2.86.1 is not. The dgVoodooCpl.exe are identical in size down to the byte but are giving back different checksums meaning that the files are different. Very, very, very strange. (on top of the website acting up)
I won't send you 2.86.2 as it's coming up as a virus. 2.86.1 isn't but I'm still not confident it's not a virus, and 2.85 is a different size. However these were all downloaded today or yesterday, and dege hasn't replied about this so his website might actually be hacked right now. I downloaded 2.84.1 on 1/15/2025 and I'm highly confident it isn't infected, and if you do want me to email you one I highly suggest you just choose this one.
